I am working through a loop of intersecting layers, in which I want to choose the largest value.
I have tried to use create a list of numbers using += . This worked fine when I was using a combo of text and numbers, but because I am now just looking at numbers it sums the values, == replaces the values. I could not see how to make a list which I could then use the MAX function with.
My next attempt was to nest an if statement so that I am only getting the largest number out but I have an illegal return statement.
Below is an example of what I am currently doing.
var intersectLayer = Intersects(FeatureSetByName($map, "layer"), $feature)
var Zones = "";
var Zones1 = "";
for (var f in intersectLayer){
if(Zones == ""){
Zones = f.Shape__Area
} else {
Zones1 = f.Shape__Area
if (Zones < Zones1){
Zones == Zones1
}else{
Zones1 == ""
Xander Bakker Is this something you can help me with? I'm expecting there to be a much easier way then I have thought of yet.
