<div id="divMenuEnvironment" class='divMenu'>
<label id="lblBIEAP" class="lblSubMenuItem"><img id="imgBIEAP" src="Images\plus.png" width="13"/>BIEAP</label><a class="aSelectAll" id="aBIEAPSelectAll"> Select All</a></br>
<div id='divMenuBIEAP' class='divSubMenu'>
<div id='txtBIEAPHighTide' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPHighTide' value=26 />High Tide Line</div>
<div id='txtBIEAPLowTide' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPLowTide' value=38 />Low Tide Line</div>
<div id='txtBIEAPShoreSeg' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPShoreSeg' value=37 />Shoreline Segments</div>
<div id='txtBIEAPOverVeg' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPOverVeg' value=36 />Overhanging Vegetation</div>
<div id='txtBIEAPShoreEros' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPShoreEros' value=35 />Shoreline Erosion</div>
<div id='txtBIEAPOutfalls' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPOutfalls' value=34 />Outfalls</div>
<div id='txtBIEAPIntFeat' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPIntFeat' value=33 />Interesting Features</div>
<div id='txtBIEAPBirdNest' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPBirdNest' value=32 />Bird Nests</div>
<div id='txtBIEAPIntPlant' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPIntPlant' value=31 />Introduced Plants</div>
<div id='txtBIEAPIntVegFeat' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPIntVegFeat' value=30 />Intertidal Vegetation Features</div>
<div id='txtBIEAPIntVegAreas' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPIntVegAreas' value=29 />Intertidal Vegetation Areas</div>
<div id='txtBIEAPIntSubs' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBIEAPIntSubs' value=28 />Intertidal Substrates</div>
</div>
<label id="lblFREMP" class="lblSubMenuItem"><img id="imgFREMP" src="Images\plus.png" width="13"/>FREMP</label><a class="aSelectAll" id="aFREMPSelectAll"> Select All</a></br>
<div id='divMenuFREMP' class='divSubMenu'>
<div id='txtFREMPColCode' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkFREMPColCode' value=43 />Colour Codes</div>
<div id='txtFREMPAreaDes' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkFREMPAreaDes' value=42 />Area Designation</div>
<div id='txtFREMPHabComp' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkFREMPHabComp' value=41 />Habitat Compensation</div>
<div id='txtFREMPHabOrd' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkFREMPHabOrd' value=40 />Habitat Order</div>
</div>
<div id='txtBoreholes' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkBoreholes' value=0 />Boreholes</div>
<img id='imgContSitesLock' src='Images\lock.png' height='0' style='float:left;' title='You do not have access to this layer'/>
<div id='txtContSites' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkContSites' value=45 />Contaminated Sites</div>
<img id='imgEnvLibLock' src='Images\lock.png' height='0' style='float:left;' title='You do not have access to this layer'/>
<div id='txtEnviroLib' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkEnvLib' value= />Enviro Library</div>
<div id='txtHabComp' class='divMenuItem'><input type='checkbox' class='enviro_list_item' id='chkHabComp' value=17 />Habitat Compensation Sites</div>
</div>
Javascript:
//The following fires when a "Select All" link is clicked to turn all layers in a subgroup on/off
$(".aSelectAll").click(function(){
//cut off the "a" and "SelectAll" from the clicked link's id
//example id would be 'aBIEAPSelectAll'
var targetSelectAll = ((event.srcElement.id).replace("SelectAll", '')).slice(1);
//piece together the id of the menu targeted
//example result would be "#divMenuBIEAP
var targetSelectMenu = "#divMenu" + targetSelectAll;
//find all the checkboxes in the divMenu and toggle them
var checked = $(this).data('checked');
$(targetSelectMenu).find(':checkbox').prop('checked', !checked);
$(this).data('checked', !checked);
$(targetSelectMenu).find(':checkbox').trigger('change');
//run the function to update the visibility of layers
updateLayerVisibility();
