Hello, i m new in network analysis and I want to driving direction in this example can any one tell me how to get driving direction using this example.
<!DOCTYPE html>
<html>
<head>
<title>Multiple Routes</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<script src="https://js.arcgis.com/3.20/"></script>
<script>
require([
"esri/urlUtils",
"esri/config",
"esri/map",
"esri/graphic",
"esri/tasks/RouteTask",
"esri/tasks/RouteParameters",
"esri/tasks/FeatureSet",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/Color",
"dojo/_base/array",
"dojo/on",
"dojo/dom",
"dijit/registry",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/form/HorizontalSlider",
"dijit/form/HorizontalRuleLabels"
], function (
urlUtils, esriConfig, Map, Graphic, RouteTask, RouteParameters,
FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol,
Color, array, on, dom, registry
var map, routeTask, routeParams, routes = [];
var stopSymbol, barrierSymbol, routeSymbols;
var mapOnClick_addStops_connect, mapOnClick_addBarriers_connect;
urlUtils.addProxyRule({
urlPrefix: "route.arcgis.com",
proxyUrl: "/sproxy/"
map = new Map("map", {
basemap: "streets",
center: [-122.416, 37.802],
zoom: 15
routeTask = new RouteTask("https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
routeParams = new RouteParameters();
routeParams.stops = new FeatureSet();
routeParams.barriers = new FeatureSet();
routeParams.outSpatialReference = {"wkid":102100};
routeTask.on("solve-complete", showRoute);
routeTask.on("error", errorHandler);
stopSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_CROSS).setSize(15);
stopSymbol.outline.setWidth(3);
barrierSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_X).setSize(10);
barrierSymbol.outline.setWidth(3).setColor(new Color([255,0,0]));
routeSymbols = {
"Route 1": new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(5),
"Route 2": new SimpleLineSymbol().setColor(new Color([0,255,0,0.5])).setWidth(5),
"Route 3": new SimpleLineSymbol().setColor(new Color([255,0,255,0.5])).setWidth(5)
//button click event listeners can't be added directly in HTML when the code is wrapped in an AMD callback
on(dom.byId("addStopsBtn"), "click", addStops);
on(dom.byId("clearStopsBtn"), "click", clearStops);
on(dom.byId("addBarriersBtn"), "click", addBarriers);
on(dom.byId("clearBarriersBtn"), "click", clearBarriers);
on(dom.byId("solveRoutesBtn"), "click", solveRoute);
on(dom.byId("clearRoutesBtn"), "click", clearRoutes);
//Begins listening for click events to add stops
function addStops() {
removeEventHandlers();
mapOnClick_addStops_connect = map.on("click", addStop);
//Clears all stops
function clearStops() {
for (var i=routeParams.stops.features.length-1; i>=0; i--) {
map.graphics.remove(routeParams.stops.features.splice(i, 1)[0]);
//Adds a stop. The stop is associated with the route currently displayed in the dropdown
function addStop(evt) {
routeParams.stops.features.push(
map.graphics.add(
new esri.Graphic(
evt.mapPoint,
stopSymbol,
{ RouteName:dom.byId("routeName").value }
//Begins listening for click events to add barriers
function addBarriers() {
mapOnClick_addBarriers_connect = on(map, "click", addBarrier);
//Clears all barriers
function clearBarriers() {
for (var i=routeParams.barriers.features.length-1; i>=0; i--) {
map.graphics.remove(routeParams.barriers.features.splice(i, 1)[0]);
//Adds a barrier
function addBarrier(evt) {
routeParams.barriers.features.push(
map.graphics.add(
new esri.Graphic(
evt.mapPoint,
barrierSymbol
//Stops listening for click events to add barriers and stops (if they've already been wired)
function removeEventHandlers() {
if (mapOnClick_addStops_connect) {
mapOnClick_addStops_connect.remove();
if (mapOnClick_addBarriers_connect) {
mapOnClick_addBarriers_connect.remove();
//Solves the routes. Any errors will trigger the errorHandler function.
function solveRoute() {
routeTask.solve(routeParams);
//Clears all routes
function clearRoutes() {
for (var i=routes.length-1; i>=0; i--) {
map.graphics.remove(routes.splice(i, 1)[0]);
routes = [];
//Draws the resulting routes on the map
function showRoute(evt) {
clearRoutes();
array.forEach(evt.result.routeResults, function(routeResult, i) {
routes.push(
map.graphics.add(
routeResult.route.setSymbol(routeSymbols[routeResult.routeName])
var msgs = ["Server messages:"];
array.forEach(evt.result.messages, function(message) {
msgs.push(message.type + " : " + message.description);
if (msgs.length > 1) {
alert(msgs.join("\n - "));
//Reports any errors that occurred during the solve
function errorHandler(err) {
alert("An error occured\n" + err.message + "\n" + err.details.join("\n"));
</script>
</head>
<body class="claro">
Select route name: <select id="routeName">
<option value="Route 1">Route 1</option>
<option value="Route 2">Route 2</option>
<option value="Route 3">Route 3</option>
</select> to
<button id="addStopsBtn">Add Stops</button>
<button id="clearStopsBtn">Clear Stops</button>
<button id="addBarriersBtn">Add Barriers</button>
<button id="clearBarriersBtn">Clear Barriers</button>
<button id="solveRoutesBtn">Solve Routes</button>
<button id="clearRoutesBtn">Clear Routes</button>
<br /><br />
<div id="map" style="width:600px; height:400px; border:1px solid #000;"></div>
<ol>
<li>Select a route name from the drop down.</li>
<li>Click 'Add stops', then click on map to add stops to route.</li>
<li>Click the 'Add Barriers', then click on map to add barriers.</li>
<li>Optionally, repeat the above steps to add more routes.</li>
<li>Click the 'Solve Routes' to solve.</li>
</ul>
<p>Any server error messages will be displayed in an alert box.</p>
</body>
</html>
