I am trying to set map extent using an offset because there is a floating panel over the map and sometimes, when I zoom to a feature extent, the feature is partly hidden behind it.
I would like to offset the extent so it will always be displayed and centred in the map section that is not hidden by the panel
This is what I tried so far without success:
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">zoomToExtent</SPAN><SPAN class="punctuation token">(</SPAN>extent<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> hiddenMapPartTopLeft <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ScreenPoint</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
hiddenMapPartBottomRight <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ScreenPoint</SPAN><SPAN class="punctuation token">(</SPAN>panel<SPAN class="punctuation token">.</SPAN>position<SPAN class="punctuation token">.</SPAN>left <SPAN class="operator token">+</SPAN> panel<SPAN class="punctuation token">.</SPAN>position<SPAN class="punctuation token">.</SPAN>width<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>container<SPAN class="punctuation token">.</SPAN>offsetHeight<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> dx <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
xmin<SPAN class="punctuation token">:</SPAN> hiddenMapPartTopLeft<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN>
ymin<SPAN class="punctuation token">:</SPAN> hiddenMapPartBottomRight<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">,</SPAN>
xmax<SPAN class="punctuation token">:</SPAN> hiddenMapPartBottomRight<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN>
ymax<SPAN class="punctuation token">:</SPAN> hiddenMapPartTopLeft<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getWidth</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
extent <SPAN class="operator token">=</SPAN> extent<SPAN class="punctuation token">.</SPAN><SPAN class="token function">offset</SPAN><SPAN class="punctuation token">(</SPAN>dx<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setExtent</SPAN><SPAN class="punctuation token">(</SPAN>extent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The map zoom way too far to the right. Is there a solution for this?
