I'm trying to use the goecoder using dojo JavaScript. When I submit the address, I have this "ReferenceError: Graphic is not defined" error message. Any clue what s happening.
Below is my code:
"esri/dijit/Geocoder",
"esri/graphic" // search
// begin geocoder
var geocoder = new Geocoder({
map: map,
autoComplete: true,
zoomScale: 600
}, dom.byId("search"));
geocoder.startup();
geocoder.on("select", showLocation);
function showLocation(evt) {
map.graphics.clear();
var point = evt.result.feature.geometry;
var symbol = new SimpleMarkerSymbol()
.setStyle("square")
.setColor([255, 0, 0, 0.5]);
var graphic = new Graphic(point, symbol);
map.graphics.add(graphic);
map.infoWindow.setTitle("Search Result");
map.infoWindow.setContent(evt.result.name);
map.infoWindow.show(evt.result.feature.geometry);
map.infoWindow.on('hide', function () {
map.graphics.remove(graphic);
// end geocoder
Error at this line:
Naveen Mandava.
