Hi All,
I'm using the following from the ESRI JS samples to toggle my layers on and off, and it works well enough: Toggle layer visibility | ArcGIS API for JavaScript
However, getting each checkbox by its id seems a rather bloated way of doing things when you're working with ~100 layers. I'm pretty new to javascript so I'm not sure of the syntax to get the checkboxes by class, or if this can even work?
I've tried multiple id's:
on(dom.byId("chkVFPABoundary", "chkMunicipalBoundaries"), "change", updateCadastralLayerVisibility);Which didn't work. Also:
on(document.getElementsByClassName(".cadastral_list_item"), "change", updateCadastralLayerVisibility); //Anything in my cadastral service has this class nameWhich didn't work. I'm pretty sure I can't use 'on' with document.getElementsByClassName? Is there something comparable?
I tried jquery:
$('.cadastral_list_item').change(function() {
if(this.checked) {
updateCadastralLayerVisibility()
});This didn't work either, nothing happens at all when the checkbox is clicked.
I've been scouring the internet all day, but can't find any clues. Thanks in advance.
