I'm trying to publish some raster datasets as WCS using ArcGIS 10.4 (Desktop and Server), but have had little success. I've attempted to publish a dataset stored as an ESRI Grid, a GeoTIFF, and a Mosaic Dataset. I'm able to connect to the WCS image server, but when I try to add the image I get the following message: "Could not add the specified data object to the map. Failed to open raster dataset."
When publishing my dataset, I select the WCS and WMS capabilities along with the Image Service. I am able to add the image as a Image Service when I connect to the ArcGIS Server just fine. I'm also able to add the published data as a WMS. The WCS is the only service that fails. Does anyone know what would cause my WCS to fail, but allow my Image Service and WMS work?
