I am querying a feature class that has thousands of objects using Select Layer by Attribute. I need to include almost 400 attributes, is there an easier way to write this besides selecting/typing out the name of each attribute?? For example: There are thousands of objects in a feature class each associated with one of hundreds of projects (already identified) and I need to select the objects only associated with a subgroup of 400 of those projects. Select Object where the Project_Name is equal to project A or Project b...x400. The selected subgroup will then be exported into a new feature class specifically for that group of projects. What is the easiest way to do this?
