Hey everyone,I'm trying to incorporate this TOC example with this Basemap example - using buttons. I got the TOC working (you won't be able to see the layer because its on my server, but I can see it from my end). I can't seem to get the basemaps to work at all.I can't seem to figure out what I'm missing here? I'm starting towards the bottom since my code is really long. </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript"> dojo.require("dijit.dijit"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); // uncomment if want dojo widget style checkbox //dojo.require('dijit.form.CheckBox'); dojo.require("esri.map"); dojo.require("dijit.layout.AccordionContainer"); dojo.require("agsjs.dijit.TOC"); dojo.require("esri.dijit.BasemapGallery"); dojo.require("dijit.Tooltip"); dojo.require("dijit.form.Button"); dojo.require("dijit.Menu"); </script> <script type="text/javascript"> var map, basemapGallery; var bingKey = 'Enter your Bing Maps Key'; function init() { var initialExtent = new esri.geometry.Extent({ "xmin" : -123.5328, "ymin" : 32.4344, "xmax" : -112.2582, "ymax" : 37.64041, "spatialReference" : { "wkid" : 102100 } }); map = new esri.Map("map", { extent : esri.geometry.geographicToWebMercator(initialExtent), }); //Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service //var grayBasemapLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Canvas/World_Light_Gray_Base/MapServer"); //map.addLayer(grayBasemapLayer); var census = new esri.layers.ArcGISDynamicMapServiceLayer("http://arcgis.focusproject.org:8399/arcgis/rest/services/2012APR11_California_Partnerships_Colleges_HealthCare_VA.gdb/MapServer", { id : 'census', opacity : 0.8 }); //var safety = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayers/MapServer", { // id : 'publicsafety', // opacity : 0.8 //}); dojo.connect(map, 'onLayersAddResult', function(results) { var toc = new agsjs.dijit.TOC({ map : map, layerInfos : [{ //layer: safety, //title: "Safety Operations" //},{ layer : census, title : "Partnerships" }] }, 'tocDiv'); toc.startup(); }); //map.addLayers([census, safety]); map.addLayers([census]); //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm var resizeTimer; createBasemapGallery(); dojo.connect(map, 'onLoad', function(theMap) { dojo.connect(dijit.byId('map'), 'resize', function() {//resize the map if the div is resized clearTimeout(resizeTimer); resizeTimer = setTimeout(function() { map.resize(); map.reposition(); }, 500); }); }); } function createBasemapGallery() { //Manually create a list of basemaps to display var basemaps = []; var basemapRoad = new esri.dijit.Basemap({ layers : [new esri.dijit.BasemapLayer({ type : "BingMapsRoad" })], id : "bmRoad", title : "Road" }); basemaps.push(basemapRoad); var basemapAerial = new esri.dijit.Basemap({ layers : [new esri.dijit.BasemapLayer({ type : "BingMapsAerial" })], id : "bmAerial", title : "Aerial" }); basemaps.push(basemapAerial); var basemapHybrid = new esri.dijit.Basemap({ layers : [new esri.dijit.BasemapLayer({ type : "BingMapsHybrid" })], id : "bmHybrid", title : "Aerial with labels" }); basemaps.push(basemapHybrid); basemapGallery = new esri.dijit.BasemapGallery({ showArcGISBasemaps : false, basemaps : basemaps, bingMapsKey : bingKey, map : map }); //BasemapGallery.startup isn't needed because we aren't using the default basemap, instead //we are going to create a custom user interface to display the basemaps, in this case a menu. dojo.forEach(basemapGallery.basemaps, function(basemap) { //Add a menu item for each basemap, when the menu items are selected dijit.byId("bingMenu").addChild(new dijit.MenuItem({ label : basemap.title, onClick : dojo.hitch(this, function() { this.basemapGallery.select(basemap.id); }) })); }); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;"> <div id="header" dojotype="dijit.layout.ContentPane" region="top"> <div> <b>Table Of Content (TOC/Legend) Widget</b><a style="right:20px;position: absolute" href="../docs/toc/examples.html">Documentation</a> </div> <ul style="margin:2px"> <li> Click check box to turn on/off layers. When click on groups, all sublayers will be turned on/off. </li> </ul> </div> <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left" splitter="true"> <div id="tocDiv"></div> </div> <div id="map" dojotype="dijit.layout.ContentPane" region="center"> <div style="position:absolute; right:50px; top:10px; z-Index:99;"> <button id="dropdownButton" iconClass="bingIcon" label="Basemaps" dojoType="dijit.form.DropDownButton"> <div dojoType="dijit.Menu" id="bingMenu"> <!--The menu items are dynamically created using the basemap gallery layers--> </div> </button> </div> </div> </div> </body> </html>
Thanks for your help...R
