Hi, I would like to get the last iteration of a loop and do a calculate field on it ! I've try to catch the last iteration with this if index !=len(fclist)-1: or if index ==len(fclist)-1:
But still not having a good resultAny suggestions ?for index, value in enumerate(fclist, start=1): looptime = time.asctime() print "Début de la boucle d'intersection en batch:" + looptime print value # Intersection arcpy.Intersect_analysis([IntersectBoucle,value],OutIntersectBoucle) print "#### " + str(i) + "ieme intersection(Boucle) ###########" print "L'intersection est entre : " + str(OutIntersectBoucle)+ " et " + str(value) fieldnames4 = [f.name for f in arcpy.ListFields(OutIntersectBoucle)] # Populate field isSame, Supported and Supporting arcpy.CalculateField_management(OutIntersectBoucle,"isSame","isSame( !Name!, !Name_1! )","Python_9.3",codeblock) arcpy.CalculateField_management(OutIntersectBoucle,"Supported","PeuplerZone ( !isSame!, !Name!)","Python_9.3",codeblock2) arcpy.CalculateField_management(OutIntersectBoucle,"Supporting","PeuplerZone ( !isSame!, !Name_1!)","Python_9.3",codeblock3) j += 1 if index !=len(fclist)-1: print "La dernière intersection est :" + str(OutIntersectBoucle) + " + 1" arcpy.CalculateField_management(OutIntersectBoucle,"isSame","poly_exc( !isSame!)","Python_9.3",codeblock4)
