I am developing a toolbox where the user can select an attribute (dropdown list) which comes from a PostGIS database and based on this attribute a select statement (selectbyAttribute) will be executed... Sounds easy...
Here is a code snippet:
input_AZ = str(arcpy.GetParameterAsText(0))
sql_exp = 'aktenzahl = ' + input_AZ ("aktenzahl" is the column (character) of the PostGIS db)
arcpy.SelectLayerByAttribute_management (lyr_postgis, "NEW_SELECTION", sql_exp)
sql_exp looks like this:
"aktenzahl = VIIa-20150429a"
but I get the following error:
ERROR 000358
[The SQL statement was not a select statement]
Does somebody know, how a SQL statement in arcpy has to look like (e.g. inverted comma) when executing on PostGIS?
Thank you in advance!
Stefan
