Using iOS 8, and it works in the browser. This is an extremely urgent and important problem - any guidance or input would be greatly appreciated. Thank you in advance!
Here is my code if you are curious:
<script>
var map;
var graphic;
var currLocation;
var watchId;
var caseArray = [
<apex:repeat value="{!cwlist}" var="cw">
{id:"{!cw.c.id}",lat:"{!cw.Latitude}",long:"{!cw.longitude}",description:"{!cw.description}",subject:"{!cw.subject}",img:"{!cw.img}",requestDate:"{!cw.infoDate}",address:"{!cw.c.Address__c}",icon:"{!cw.c.Icon_String__c}"},
</apex:repeat>
require([
"esri/map",
"esri/geometry/Point",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/graphic",
"esri/Color",
"esri/layers/GraphicsLayer",
"dojo/domReady!"
], function(
Map, Point, SimpleMarkerSymbol, SimpleLineSymbol, Graphic, GraphicsLayer,Color
var lastItemIndex = caseArray.length-1;
map = new Map("map", {
basemap: "streets",
autoResize:false,
center: [caseArray[lastItemIndex].long,caseArray[lastItemIndex].lat],
zoom: 14
//MAP ON LOAD CODE
map.on("load", function() {
//default icon
var s = new esri.symbol.PictureMarkerSymbol("https://cdn1.iconfinder.com/data/icons/Map-Markers-Icons-Demo-PNG/256/Map-Marker-Marker-Outside-Azure.png",30,30);
var p;
var g;
for(var i = 0; i < caseArray.length; i++) {
console.log('adding graphic...');
p = new Point(caseArray.long,caseArray.lat);
s = new esri.symbol.PictureMarkerSymbol('https://na10.salesforce.com' + caseArray.icon,30,30);
g = new Graphic(p, s).setAttributes({'id':caseArray.id,'subject':caseArray.subject,'description':caseArray.description,'img':caseArray.img,'requestDate':caseArray.requestDate,'longitude':caseArray.long,'latitude':caseArray.lat,'address':caseArray.address,'icon':caseArray.icon});
map.graphics.add(g);
//console.log(caseArray.lat+' ARG '+caseArray.long);
//map.addLayer(gl);
map.graphics.enableMouseEvents();
dojo.connect(map.graphics, "onClick", function(e) {
showRecord(e.graphic.attributes);
if(navigator.geolocation ) {
navigator.geolocation.getCurrentPosition(zoomToLocation, locationError);
watchId = navigator.geolocation.watchPosition(showLocation, locationError);
} else {
alert("Browser doesn't support Geolocation. Visit http://caniuse.com to see browser support for the Geolocation API.");
}); //End map on load
map.on('reposition', function(evt) {
console.log(evt.x+','+evt.y);
function locationError(error) {
//error occurred so stop watchPosition
if( navigator.geolocation ) {
navigator.geolocation.clearWatch(watchId);
switch (error.code) {
case error.PERMISSION_DENIED:
alert("Location not provided");
break;
case error.POSITION_UNAVAILABLE:
alert("Current location not available");
break;
case error.TIMEOUT:
alert("Timeout");
break;
default:
alert("unknown error");
break;
function zoomToLocation(location) {
currentLongitude = location.coords.longitude;
currentLatitude = location.coords.latitude;
var pt = new Point(location.coords.longitude, location.coords.latitude);
addGraphic(pt);
map.centerAndZoom(pt, 15);
function showLocation(location) {
//zoom to the users location and add a graphic
if ( !graphic ) {
addGraphic(pt);
} else { // move the graphic if it already exists
graphic.setGeometry(pt);
map.centerAt(pt);
function addGraphic(pt){
var symbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
12,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([210, 105, 30, 0.5]),
8
new Color([210, 105, 30, 0.9])
graphic = new Graphic(pt, symbol);
map.graphics.add(graphic);
var is1 = true;
function showInfoPanel(name, hideName, attributes) {
//if (attributes.img != '') $('.'+name).find('.media-object').attr('src','/resource/'+attributes.img);
$('.'+name).find('.media-object').attr('src',attributes.icon);
$('.'+name).find('.media-heading').html(attributes.subject);
$('.'+name).find('.media-date').html(attributes.requestDate);
//$('.'+name).find('.media-text').html(attributes.description);
console.log('Address:'+attributes.address);
$('.'+name).find('.media-address').html(attributes.address);
$('.'+name).attr('onclick','setCaseViewContent(\''+attributes.id+'\',\''+attributes.subject+'\',\''+attributes.description+'\',\''+attributes.latitude+'\',\''+attributes.longitude+'\',\''+attributes.img+'\',\''+attributes.requestDate+'\',\''+attributes.address+'\',\''+attributes.icon+'\');navigateTo(\'CaseView\');');
$('.'+name).removeClass('fadeOutDown');
$('.'+name).addClass('animated fadeInUp');
$('.'+name).show();
$('.'+hideName).removeClass('fadeInUp');
$('.'+hideName).addClass('fadeOutDown');
function showRecord(attributes) {
console.log(attributes);
console.log(attributes.id);
if(is1) {
console.log('is1 is true');
showInfoPanel('caseInfoPanel','caseInfoPanel2',attributes);
is1 = false;
}else {
console.log('is1 is false');
showInfoPanel('caseInfoPanel2','caseInfoPanel',attributes);
is1 = true;
if($('.caseInfoPanel').is(":visible")) {
console.log('info is showing');
$('.caseInfoPanel').removeClass('animated fadeInUp');
$(".caseInfoPanel" ).fadeOut( "50", function() {
$('.caseInfoPanel').addClass('animated fadeInUp');
$('.caseInfoPanel').show();
}else{
</script>
