I want to have a map load as soon as the page is open...it will plot all 1000+ points on the map...then at the top of the page there is a text box where the user can filter the map. Once the button is clicked it should kick off a query task and query the layer only showing those that were typed in the text box. I keep getting the error executeQueryTask is not defined...I know I am missing something simple but cant figure it out. My code is below:function init() {
queryTask = new esri.tasks.QueryTask("https://myserver/Locations/MapServer/0");
//initialize query
query = new Query();
query.returnGeometry = true;
query.outFields = ["*"];
function executeQueryTask() {
//set query based on what user typed in for population;
query.where = "QUALIFICAT IN " + QUALIFICAT;
//execute query
queryTask.execute(query,showResults);
function showResults(featureSet) {
//remove all graphics on the maps graphics layer
map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures = featureSet.features;
//Loop through each feature returned
for (var i=0, il=resultFeatures.length; i<il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic = resultFeatures;
graphic.setSymbol(symbol);
//Set the infoTemplate.
graphic.setInfoTemplate(infoTemplate);
//Add graphic to the map graphics layer.
map.graphics.add(graphic);
<body>
<br/>
Qualification Type: <input type="text" id="QUALIFICAT" value="OT" />
<input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('QUALIFICAT').value);" />
<div id="map"></div>
<div id="footer"
data-dojo-TYPE="dijit.layout.ContentPane"
data-dojo-props="region:'bottom'">
</div>
