I have a rather complex query that I'm running and the results need to go into a dGrid which is formatted with a renderRow. I have successfully used this in the past. I think it might be the size of my data set, because I'm getting an error in my renderRow function that the object I should be passing isn't yet available.
Sometimes this works. Otherwise, if I put a breakpoint in my renderRowFunction, this gives the process enough time to format my data and then it works.
var dataGrid = new declare([Grid, Selection]);
datagrid = new dataGrid({
showHeader: false,
renderRow:renderRowFunction
}, "gridDiv");
function renderRowFunction(obj, options){
var template = '<div class="gridTitle gridInfo">${0}</div><div class="details gridInfo">${1}</div> <div class="details gridInfo">${2}</div><div class="details gridInfo"> ${3}, ${4}</div><div class="details gridInfo">${5}</div><div class="details gridInfo provider">Provider Type: ${6}</div><div class="details gridInfo provider">Specialty: ${7}</div>';
var divString = String.substitute(template, [obj.facility, obj.address,obj.address2, obj.city,obj.state,obj.phone,obj.provider,obj.specialty])
var div = domConstruct.create("div", {
innerHTML: divString
return div;
}The grid is populated from featureLayer, which has a definition expression on it. Since that filter is in place, I only need to a simple where clause to get all the elements to populate the grid. I also have an extent-change listeners to limit the contents to the current map extent.
function updateGrid(){
var query = new Query();
query.where = '1=1';
query.geometry = currentExtent;
featureLayer.on("selection-complete", featureLayerQueryHandler, errorHandler);
featureLayer.selectFeatures(query);
function featureLayerQueryHandler(response){
var data = [];
data = arrayUtils.map(response.features, function(feature){
return {
'id': feature.attributes.ESRI_OID,
'facility': feature.attributes.NA_PROVIDER,
'address': feature.attributes.AD_LINE1,
'address2':feature.attributes.AD_LINE2,
'city': feature.attributes.AD_CITY,
'state': feature.attributes.AD_STATE,
'phone':phoneFormatter(feature.attributes.PH_NUMBER),
'provider':findProvCode(feature.attributes.ID_PROV_TYPE_FK),
'specialty':findSpecCode(feature.attributes.ID_SPECIALTY_FK)
var currentMemory = new Memory({
data: data,
idProperty: 'id'
datagrid.set('store', currentMemory);
datagrid.sort('facility'); }
Could I set something up to only define the renderRow after datagrid is populated?
