Hi everybody,
currently we are trying to use the ArcGIS SDK for JS inside an Angular application together with the TypeScript definitions(@types/arcgis-js-api) and are running into some compiler problems on the imports..
What we did:
We followed this guide to create an ArcGIS + Angular application: Angular | ArcGIS API for JavaScript 4.14
This is running fine with these imports:
import Map from 'arcgis-js-api/Map';
import MapView from 'arcgis-js-api/views/MapView';
Then we tried to use this guide to install the TypeScript type definitions: TypeScript - Setting up your development environment | ArcGIS API for JavaScript 4.14
And here comes the problem. We added the definitions and can see them in our node_modules/@types folder. And WebStorm can find them aswell. When we try to import Map or MapView it suggests
import Map from 'esri/Map';
import MapView from 'esri/views/MapView';
It gets the link to the correct file and our instances of Map and MapView got the correct properties and methods BUT the TypeScript compiler complains that it is not able to find these modules: "TS2307: Cannot find module 'esri/Map'."
We then looked at the demo project: jsapi-resources/4.x/typescript/demo at master · Esri/jsapi-resources · GitHub
The demo project itself is working aswell, just without Angular.
If we look at the differences, we found some compiler differences in the tsconfig.json file which we tried but didn't work.
What we found suspicious: the type definitions are in the folder @types/arcgis-js-api and NOT in @types/esri how it would be normally, as the modules are exported with "esri/..."
Any ideas or help would be appreciated
Lars
Our tsconfig file:
"compileOnSave": false,
"compilerOptions": {
"baseUrl": "./",
"outDir": "./dist/out-tsc",
"sourceMap": true,
"declaration": false,
"downlevelIteration": true,
"experimentalDecorators": true,
"module": "esnext",
"moduleResolution": "node",
"importHelpers": true,
"target": "es5",
"typeRoots": [
"node_modules/@types"
"lib": ["dom", "es2015.promise", "es5", "es6"]
"angularCompilerOptions": {
"fullTemplateTypeCheck": true,
"strictInjectionParameters": true
