Dear friends,PLEASE HELP ME....STRUGGLING TO SOLVE THIS ISSUEI developed one application for showing googlemap in my silverlight based ESRI application based on the code explaining here in this linkhttp://rexdotnet.blogspot.com/2010/09/use-google-maps-with-arcgis-silverlight.htmlEverything working perfect except one problem at the time of zoom and pan the map.When I try to display a polygon on my googlemap,First time it is showing on correct location .But when I zoom or pan the map ,polygon is not moving with map.After pan the map polygon is showing in another location .how to solve this issue? Adding polygon using the following codePrivate Sub AddPolygonGraphics(coordinateString1 As String, Gname As String, Gdesc As String)
Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayer"), GraphicsLayer)
Dim pointConverter As New PointCollectionConverter()
Dim pointCollection1 As ESRI.ArcGIS.Client.Geometry.PointCollection = TryCast(pointConverter.ConvertFromString(coordinateString1), ESRI.ArcGIS.Client.Geometry.PointCollection)
Dim polygon1 As New ESRI.ArcGIS.Client.Geometry.Polygon()
polygon1.Rings.Add(pointCollection1)
_activeSymbol = TryCast(LayoutRoot.Resources("DefaultFillSymbolT"), Symbol)
Dim graphic As New Graphic() With
.Geometry = mercator.FromGeographic(polygon1),
.Symbol = _activeSymbol
polygon1.SpatialReference = New SpatialReference(4326)
Dim strhotspot As String = ""
strhotspot = Trim(Gname)
If Gdesc <> "" Then
strhotspot = strhotspot & "," & Trim(Gdesc)
End If
graphicsLayer.Graphics.Add(graphic)
MyMap.ZoomTo(graphicsLayer.FullExtent)
End SubUSING THE BELOW CODE I AM CALLING THE MAP EACH TIMEImports ESRI.ArcGIS.Client
Imports ESRI.ArcGIS.Client.Geometry
Public Class GoogleStaticMapLayer
Inherits DynamicMapServiceLayer
Private Shared mercator As New ESRI.ArcGIS.Client.Projection.WebMercator()
Private Const cornerCoordinate As Double = 20037508.3427892
Private Const WKID As Integer = 102100
Public Sub New()
MyBase.New()
End Sub
Private Property Lods() As Lod()
Get
Return m_Lods
End Get
Set(value As Lod())
m_Lods = Value
End Set
End Property
Private m_Lods As Lod()
Public Overrides Sub Initialize()
Me.FullExtent = New ESRI.ArcGIS.Client.Geometry.Envelope(-cornerCoordinate, -cornerCoordinate, cornerCoordinate, cornerCoordinate) With { _
.SpatialReference = New SpatialReference(WKID) _
Me.SpatialReference = New SpatialReference(WKID)
Lods = New Lod(20) {}
Dim resolution As Double = cornerCoordinate * 2 / 256
For i As Integer = 0 To Lods.Length - 1
Lods(i) = New Lod() With { _
.Resolution = resolution _
resolution /= 2
MyBase.Initialize()
End Sub
Public Overrides Sub GetUrl(extent As ESRI.ArcGIS.Client.Geometry.Envelope, width As Integer, height As Integer, onComplete As DynamicMapServiceLayer.OnUrlComplete)
Dim geogCenterPoint As MapPoint = Nothing
Dim mapURL As String = Nothing
Try
Dim currentResolution As Double = extent.Width / width
Dim currentLodIndex As Integer = 0
Dim requestWidth As Integer = 0
Dim requestHeight As Integer = 0
Dim lod As Lod = Lods(i)
currentLodIndex = i
If CInt(lod.Resolution) <= CInt((currentResolution)) Then
requestWidth = CInt(extent.Width / lod.Resolution)
requestHeight = CInt(extent.Height / lod.Resolution)
Exit For
End If
geogCenterPoint = TryCast(mercator.ToGeographic(extent.GetCenter()), MapPoint)
mapURL = String.Format("http://maps.google.com/maps/api/staticmap?center={0},{1}&zoom={2}&size={3}x{4}&scale=2&maptype=roadmap&sensor=false&key=AIzaSyDoFucUPlE1lpMxNqc1-cN-dihqGZuLYUw", geogCenterPoint.Y, geogCenterPoint.X, currentLodIndex, requestWidth, requestHeight)
Catch ex As Exception
Return
End Try
onComplete(mapURL, width, height, New ESRI.ArcGIS.Client.Geometry.Envelope() With { _
.XMin = extent.XMin, _
.YMin = extent.YMin, _
.XMax = extent.XMax, _
.YMax = extent.YMax _
End Sub
End Class
Please help me.It is very urgent...Thank UUUU
