I have a field collector application recording cross walks. Right now I have a series of domains to allow for easy fills of select fields such as if a certain measurement for the crosswalk passes or fails inspection. These pass fails are based on recorded measurements.
Is there anyway that I can get the pass/fail fields to auto fill for my field workers based on the answer they in place in the integer measurement field.
Ex) ramp1_slope% is greater than 8% so ramp1_pass_fail field auto fills with fail. (ramp1_pass_fail has the domain: pass, fail. ramp1_slope% is integer field)
I am debating remaking this collector into a 123 survey but am concerned about point accuracy and if it would really save my field workers any time.
I am a novice at python mostly use it for calculations and know just enough arcade to make a pop-up for webmaps.
Thank you for your time and advice
