Trying to set output Extent for Topo To Raster in Python
Ok, So the code is below. It works except the way its written it uses the default output extent. I need to be able to add a shapefile as the output extent, or a variable (which is a shapefile declared at the top of the code). It seems there are a few different ways to do the topo to raster syntax. This one works, I just need to add the output extent and I dont know where exactlly?
My variable for my output extent is: MEG_counties_shp__2_
# Process: Topo to Raster
from arcpy.sa import *
import arcpy
outTTR = TopoToRaster([TopoPointElevation([['R:\\PrecipMap\\DailyPrecip.shp', 'pcpn']])], "0.003", "", "20", "", "", "ENFORCE", "CONTOUR", "40", "", "1", "0", "", "")
outTTR.save("R:\\ArcGIS\\Default.gdb\\TopoToR_shp2")
print 'Topo To Raster Done'
I have tried this but it does not work:
outTTR = TopoToRaster([TopoPointElevation([['R:\\PrecipMap\\DailyPrecip.shp', 'pcpn']])], "0.003", MEG_counties_shp__2_,"", "20", "", "", "ENFORCE", "CONTOUR", "40", "", "1", "0", "", "")
