I would like to be able to turn on and off a Georss feed via a check box. I tried to use this example as a guide http://jsfiddle.net/D3J8H/12/ Thank you for the help. <!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=yes"> <meta http-equiv="X-UA-Compatible" content="IE=edge"> <meta name="apple-mobile-web-app-capable" content="yes"> <meta name="apple-mobile-web-app-status-bar-style" content="black-translucent"> <title>Title</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body { height: 100%; margin: 0; padding: 0; width: 100%; } #map{ padding:0px; height: 100%; width: 100%; } #subfooter { font-size:small; color: #ffffff; font-size:13px; text-align:left; margin: 1px; } .roundedCorner { background-color: #FFFFFF; border: 1px solid #066DAB; border-radius: 4px; } #header { margin:0px; padding: 0px; background-color:#0072AF; color:#0072AF; border: solid 1px #000000; height: 50px; } #title { font-size:150%; color: #ffffff; text-align:left; margin: 2px; } #BasemapToggle { position: absolute; top: 20px; right: 20px; z-index: 50; } .esriControlsBR { display: none; } </style> <script>var dojoConfig = { parseOnLoad: true }</script> <script src="http://js.arcgis.com/3.8/"></script> <script> require([ "esri/map", "esri/dijit/BasemapToggle", "esri/layers/GeoRSSLayer", "esri/InfoTemplate", "dojo/parser", "dojo/_base/array", "dojo/dom-style", "esri/symbols/PictureMarkerSymbol", "esri/renderers/SimpleRenderer", "dojo/_base/Color", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map,BasemapToggle, GeoRSSLayer, InfoTemplate, parser, arrayUtils, domStyle, PictureMarkerSymbol, SimpleRenderer, Color){ parser.parse(); var map; map = new Map("map", { basemap: "streets", center: [-83.018, 34.005], zoom: 8 }); var toggle = new BasemapToggle({ map: map, basemap: "satellite" }, "BasemapToggle"); toggle.startup(); //////////////////////////////////////////////////////////////////// var geoLayerRss = new GeoRSSLayer("http://www.AGeorrssFeed.xml"); geoLayerRss.on("load", function () { // domStyle.set("loading", "display", "none"); // create an info template var template = new InfoTemplate("${title}", "<tr><td></td><td>${description}</td></tr><br/><br/>"); // set the info template for the feature layers that make up the GeoRSS layer // the GeoRSS layer contains one feature layer for each geometry type var layers = geoLayerRss.getFeatureLayers(); var picRenderer = new PictureMarkerSymbol("http://static.arcgis.com/images/Symbols/Basic/GreenShinyPin.png", 21, 21); var georssRenderer = new SimpleRenderer(picRenderer); arrayUtils.forEach(layers, function (cl) { cl.setInfoTemplate(template); cl.setRenderer(georssRenderer) }); }); map.addLayers([geoLayerRss]); }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width: 100%; height: 100%; margin: 0;background-color: #000000;"> <div id="header" dojotype="dijit/layout/ContentPane" region="top"> <div id="title">Main Title<div id="subfooter"> SubTitleMain</div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="border-radius: 2px;"> <div id="BasemapToggle"></div> </div> </div> </body> </html>
