ArcGIS Server on this machine is ok, but whenever we try and access the geoevent server manager page we’re getting a “No service was found” message instead of the login page. The geoevent server can’t start up correctly. I tried several fixes from the forums:
- verified the license file
- removed cache and lock files from C:\Program Files\ArcGIS\Server\GeoEvent\data
- tried completely uninstalling, deleting files from c:\ProgramData\ and then reinstalling
In the karaf.log file (attached), I’m seeing this error…
2017-12-15 16:05:44,301 | ERROR | FelixStartLevel | HttpClientService | 100 - com.esri.ges.framework.httpclient - 10.5.1 | Failed to read certificate file at C:\arcgisserver\config-store\machines\AZGEOEVENT2\geoeventExport.pfx.cer: signed fields invalid
2017-12-15 16:05:44,302 | INFO | FelixStartLevel | HttpClientService | 100 - com.esri.ges.framework.httpclient - 10.5.1 | signed fields invalid
I also see this entry...
2017-12-15 16:06:00,274 | ERROR | ator-Framework-0 | CuratorFrameworkImpl | 386 - curator-framework - 3.1.0 | Background retry gave up
org.apache.curator.CuratorConnectionLossException: KeeperErrorCode = ConnectionLoss
The arcgis server is running with a valid third party cert, and I’m not sure why the .pfx file would even be renamed .cer? The other certs in that directory, including the one used for ArcGIS Server are all ok. In arcgis server admin all looks good.
You can access arcgis server manager at:
https://www.napermaps.com:6443/arcgis/manager
You can see from that it’s using a valid cert from Entrust.
Any thoughts or suggestions would be great! Unsure where to go from here.
