I'm trying to replicate this code (both delete) in python, my previous question is related to this
arcpy 10.3.1 being used with proper license
using coverage files
display 0
arcedit
&if [show program] ne ARCEDIT &then &do /*IF1
&type ERROR: The Arcedit module could not be invoked
&setvar run_status := -1002
&return
&end /*IF1
/*** Remove non-topological lines
graphics off
edit %path_poly_cover%
editfeature line
select line_type in {%valid_line_type_list%}
nselect
&if [show number select] gt 0 &then &do /*IF1
delete
&end /*IF1
/*** Remove non-topological points
editfeature point
select pnt_type in {%valid_pnt_type_list%}
nselect
delete
&end /*IF1
save
removeedit %path_poly_cover% yes
/*** Return to the arc module
&if [show program] eq ARCEDIT &then &do /*IF1
removeedit all yes
quit yes
&end /*IF1<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
