Hi; i have a feature service;
it has subtype fields and related differend domains for each subtypes.
feature service fields:
field x = (subtype)
value: "1" Label "a"
value: "2" Label "b"
value: "3" Label "c"
field y
if select subtype 1 domain: "k"
if select subtype 2 domain: "l"
if select subtype 3 domain: "m"
Normaly with edit widget; i can add values by selecting a value from "field x"
then i can choose a value from "field y" by related domain values
But in query widget;
i am trying to choose a point by selecting a value from "field x" and by choosing "Values filtered by previous expressions" a value from "field y"
But after choosing a value from "field x", in "field y" populates all domain values "k-l-m"
SQL EXPRESSİON
(field x = 2) AND (Field y= 'k')
How to make
SQL EXPRESSİON
(field x = b) AND (Field y= 'k')
i want to choose from "field x" then "field y" related domain records only.
in query widget guide page there is a note;
Caution:
To display the description for coded values when Values filtered by previous expressions or Values filtered by all other expressions is selected, the service must support the capability of query by statistics.
In my service;
Advanced Query Capabilities:
Supports Statistics: true
Supports Pagination: true
Supports TrueCurve: false
