I am trying to load operational layers data from the following JSON with no luck.
So far I tried the following:
- add it as a graphic layer by using
graphicLayer = new esri.layers.GraphicsLayer(); graphicLayer.add(json); map.add(graphicLayer); - tried to normalize it and add as a graphic using
normalizeUtils.normalizeCentralMeridian
Is there something I am missing, for reference I am trying to follow this example http://resources.arcgis.com/en/help/arcgis-web-map-json/index.html#/ArcGIS_feature_service_operational_layers/02qt00000017000000/
Its my first time with Arcgis, I have a sample JSON of a previously drawn line on the map that I am trying to load with no luck. Here is a JSFiddle of what I am trying.
