Edited for HORRIBLE spelling
Edited to put in the correct place
I'm working on a FlexViewer application (3.6) For some reason, after about 4 days of working on it I'm not getting any response from my pop ups.
I've re-published my services, tried new applications with the same features and nothing happen
Here's the config file I made for a quick and dirty example I made just to test if it was application-specific and it's not. I'm probably missing something obvious, an extra set of eyes would be welcome.
Thanks in advance
<?xml version="1.0" ?>
<configuration>
<title>Flood Plain Inquiries</title>
<logo>assets/images/logo.png</logo>
<style>
<colors>0x444444,0xebf4ff,0xebf4ff,0xdeebff,0x444444</colors>
<alpha>0.78</alpha>
<font name="Verdana"/>
<titlefont name="Verdana"/>
<subtitlefont name="Verdana"/>
</style>
<!-- replace the following url with your own geometryservice -->
<geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
<widget url="widgets/Navigation/NavigationWidget.swf" config="widgets/Navigation/NavigationWidget.xml" left="10" top="50"/>
<widget url="widgets/OverviewMap/OverviewMapWidget.swf" config="widgets/OverviewMap/OverviewMapWidget.xml" right="0" bottom="0"/>
<widget url="widgets/MapSwitcher/MapSwitcherWidget.swf" config="widgets/MapSwitcher/MapSwitcherWidget.xml" right="20" top="55"/>
<widget url="widgets/HeaderController/HeaderControllerWidget.swf" config="widgets/HeaderController/HeaderControllerWidget.xml" left="0" top="0"/>
<map attributionvisible="true" esrilogovisible="true" openhandcursorvisible="false" scalebarvisible="true" scalebar="default" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-8149033.957970165 5036813.399624566 -8115573.648838375 5054279.260587705" wkid="102100" top="40" portalurl="https://www.arcgis.com/">
<basemaps>
<layer type="tiled" label="Topographic" icon="https://www.arcgis.com/sharing/rest/content/items/6e03e8c26aad4b9c92a87c1063ddb0e3/info/thumbnail/topo_map_2.jpg" url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" visible="true"/>
</basemaps>
<operationallayers>
<layer type="feature" label="Parcels" url="http://mgis:6080/arcgis/rest/services/Basemap/MapServer/4" popupconfig="popups/PopUp_2.xml" mode="onDemand" visible="true"/>
<layer type="feature" label="Buildings" url="http://mgis:6080/arcgis/rest/services/Basemap/MapServer/2" popupconfig="popups/PopUp_3.xml" mode="onDemand" visible="true"/>
<layer type="feature" label="Calls" url="http://mgis:6080/arcgis/rest/services/Projects/Flood_info_calls/FeatureServer/0" popupconfig="popups/PopUp_1.xml" mode="onDemand" visible="true"/>
</operationallayers>
</map>
<widgetcontainer layout="float">
<widget url="widgets/Draw/DrawWidget.swf" config="widgets/Draw/DrawWidget.xml" label="Draw" icon="assets/images/i_draw2.png"/>
<widget url="widgets/Print/PrintWidget.swf" config="widgets/Print/PrintWidget.xml" label="Print" icon="assets/images/i_print.png"/>
<widget url="widgets/Edit/EditWidget.swf" config="widgets/Edit/EditWidget_1.xml" label="Information Request" icon="assets/images/i_edit.png" preload="open"/>
<widget url="widgets/Search/SearchWidget.swf" config="widgets/Search/SearchWidget_1.xml" label="Search by Address" icon="assets/images/i_search.png" preload="open"/>
<widget url="widgets/LayerList/LayerListWidget.swf" config="widgets/LayerList/LayerListWidget_1.xml" label="Layer List" icon="assets/images/i_layers.png"/>
</widgetcontainer>
</configuration>
