Good morning all
I am trying to calculate the distance between points in two different feature layers using Arcade.
Using FeatureSetById I can pull the data for the related feature layer, but how do I use the geometry of the related feature in the arcade Distance function?
Please help, I cannot find any documentation on how to do this.
Gavin
//First read out the unique id of current feature
var A1 = $feature.holenumber
//Access the second feature
var A2 = FeatureSetById($map, /* Designed_drilling */ "Designed_drilling_3788", ['holenumber'], true)
//create sql expression
var A3 = "holenumber = '" + A1 + "'"
// filter the second feature using the sql expression
var A4 = Filter(A2, A3)
return A4
//Distance($feature, $A4, 'meters')
