Hi,I have a Feature Layer that display results in a dojo datagrid. I would like to have the ability to click on the row and zoom to the related feature. I have this functionality working for dynamic layers, but when I try to use the same code for Feature Layers it does not work. Is there a difference in how dynamic layers and feature layers are zoomed to? Thanks for any info!!
function onDrawEnd(extent){
navToolbar.deactivate();
//id = "control";
//select features within the draw extent
var query = new esri.tasks.Query();
query.geometry = extent;
featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW,function(features,selectionMethod){
//add selected features to the grid
if (document.getElementById("contSel").checked){
showPointNameGrid();
} else if(document.getElementById("survSel").checked){
showSurveysNameGrid();
var items = dojo.map(features,function(feature){
return feature.attributes;
if(document.getElementById("contSel").checked){
searchType="selControl2";
var data = {identifier:"POINT_NAME", items:items};
var store = new dojo.data.ItemFileReadStore({data:data});
var grid = dijit.byId('grid4');
grid.setStore(store);
featureLayer.selectFeatures.clear;
} else if (document.getElementById("survSel").checked){
var data = {identifier:"OBJECTID", items:items};
var grid = dijit.byId('grid5');
function toggleSelect (el)
alert(el.checked);
if (el.checked)
switch (el.id)
case 'survSel':
searchType="selSurveys2";
document.getElementById('contSel').checked = false;
featureLayerUrl = "http://slcarcgisdev1/SLCOGIS/rest/services/public/SurveyorFS/FeatureServer/2";
featureLayer = new esri.layers.FeatureLayer(featureLayerUrl,{
mode:esri.layers.FeatureLayer.MODE_ONDEMAND,
outFields:["OBJECTID"]
featureLayer.setSelectionSymbol(new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255,255,0,0.5])));
map.addLayer(featureLayer);
break;
case 'contSel':
document.getElementById('survSel').checked = false;
featureLayerUrl = "http://slcarcgisdev1/SLCOGIS/rest/services/public/SurveyorFS/FeatureServer/0";
outFields:["*"]
featureLayer.setSelectionSymbol(new esri.symbol.SimpleMarkerSymbol().setSize(8).setColor(new dojo.Color([160,214,238])));
break;
} else
switch (el.id)
case 'survSel':
document.getElementById('contSel').checked = true;
break;
case 'contSel':
document.getElementById('survSel').checked = true;
break;
//Zoom to Feature when row is clicked
function onRowClickHandler(evt){
} if (searchType == "selControl2") {
var clickedTaxLotId = grid4.getItem(evt.rowIndex).POINT_NAME;
var selectedTaxLot;
dojo.forEach(map.graphics.graphics,function(graphic){
if((graphic.attributes) && graphic.attributes.POINT_NAME === clickedTaxLotId){
selectedTaxLot = graphic;
//added this part to build infotemplate
map.infoWindow.setTitle(graphic.getTitle());
map.infoWindow.setContent(graphic.getContent());
return;
if ( selectedTaxLot.geometry.declaredClass == 'esri.geometry.Point' ) {
map.centerAndZoom(selectedTaxLot.geometry, 11)
var sp = map.toScreen(selectedTaxLot.geometry);
map.infoWindow.show(selectedTaxLot.geometry, map.getInfoWindowAnchor(sp));
} else {
//alert("Polygon");
var taxLotExtent = selectedTaxLot.geometry.getExtent();
var screenpoint = map.toScreen(selectedTaxLot.geometry.getExtent().getCenter());
var mappoint = map.toMap(screenpoint);
map.centerAndZoom(selectedTaxLot.geometry,15);
map.infoWindow.show(taxLotExtent.getCenter(), map.getInfoWindowAnchor(screenpoint));
