Not every graphic in our feature dataset has geometry and I'd like to add a column to the datagrid to identify this. Before assigning the feature layer to the datagrid graphics layer, I loop thru the graphics and add an attribute called "HasShape" and assign a value of "True" or "False" (string data type not boolean).When I debug my code, the attribute list includes "HasShape" but this is the exception I get when I bind the data to the grid:'HasShape' property not found on 'ESRI.ArcGIS.Client.Toolkit.DataSource.TempTypeMinus2021084955' Here's the code I'm using to add the attribute:Dim lyr As New ESRI.ArcGIS.Client.FeatureLayer lyr = CType(Mainpage.MyMap.Layers("MyFeatureLayer"), ESRI.ArcGIS.Client.FeatureLayer) For Each item As ESRI.ArcGIS.Client.Graphic In lyr.Graphics If item.Geometry Is Nothing Then item.Attributes.Add("HasShape", "False") Else item.Attributes.Add("HasShape", "True") End If Next Mainpage.MyDataGrid.GraphicsLayer = Mainpage.MyMap.Layers("MyFeatureLayer")I do NOT auto generate the datagrid's columns so here is my code to add the "HasShape" column: Dim col As New DataGridTextColumn col.Binding = New Windows.Data.Binding("HasShape") col.Header = "Has Shape" col.Width = New DataGridLength(80.0) col.IsReadOnly = True MyDataGrid.Columns.Add(col)Please let me know if this is possible or maybe there's a better way to identify if there's a geometry.Thanks,Jeff
