I am wanting to (from Windows 10 desktop) to run a python script that exports the table from feature classes, within a feature dataset, in an ArcSDE environment. I can manually run the script in ArcMap everyday, but this will add to the tasks that I already have. I need the script to run outside of ArcGIS so I can automatically run the script with Scheduled Tasks in Windows.
I have created the connection file and can list feature datasets and classes but I cannot figure out how to use the arcpy "table to excel" tool on the feature datasets within feature classes.
What I have so far:
# Import arcpy module
import arcpy
from arcpy import env
import os
arcpy.env.workspace = "G:\Location_of_Connection.sde_file"
Utility_Pipe = "Utility_pipe_???_Unsure how to point directly at the FC in SDE"
Utility_xls = "Location of Utility Excel\Utility.xls"
# Process: Table To Excel
arcpy.TableToExcel_conversion(Utility_Pipe, Utility_xls, "NAME", "CODE")
print "done"
I using ArcMap 10.3.1 in an enterprise geodatabase on windows 10.
Thanks!
