I have been testing different setups with our new Portal instance and am a little confused on the best way to set up for editing. I have created featureclasses in our SDE geodatabase with versioning. I have added the FCs as layers into ArcDesktop and then published as a hosted featurelayer to Portal. I can now add shapes. The problem is that if I go back to the original ArcDesktop document, the map and geodatabase are not being updated.
I originally tried publishing as a ArcServer featurelayer but could not find documentation on how I could add this layer to Portal and allow editing. All documentation that I found discussed editing the settings for a "hosted" featurelayer. How do I get my edits into my geodatabase? Any tips on the best way to set up editing?
