Hi all. I have been using below script/tool for a very long time and have gotten used to how easy it was for me to take 100+ maps, click 2 things and come back to beautifully exported or printed dataset. My tool has stopped immediately after we upgraded to 10.2 from 10.0. I am sure it is something as silly as missing a squigly line somewhere. It seems that every release of arcmap is followed by some minor change. Initially with VB to Py I had to source all scripts to make them work and now my main stopped working. Any thoughts/comments would be appreciated. Thank you.
Batch Export and Print
This script takes MXD files
and exports all the maps as selected
@author Steven Porter
@contact: porters1@ohio.edu
@organization: The Voinovich School for Leadership and Public Affairs, Ohio University
@version 1/20/11
import arcpy, sys, os
#Input variables. Remember arcgis passes lists as semicolon delimited strings (files)
files= sys.argv[1]
yesPDF = sys.argv[2]
yesJPG = sys.argv[3]
yesPNG = sys.argv[4]
yesEMF = sys.argv[5]
yesAI = sys.argv[6]
yesPRINT = sys.argv[7]
printer = sys.argv[8] #relies on code to generate a list in the tool itself
outputFolder = sys.argv[9]
mergePDF = sys.argv[10]
#if outputFolder is empty use mxd location
if outputFolder=="#":
outputFolder = os.path.dirname(files.split(";")[0])
if yesPDF=="true" and mergePDF =="true":
combinedpdf = arcpy.mapping.PDFDocumentCreate(outputFolder + os.sep + "CombinedMaps.pdf")
#loop through each passed mxd file split the string back into the list
for file in files.split(";"):
file=file.strip("'")
#parse out the file name of the file
filename = os.path.basename(file)
#get the name of file without any file extension
mxd_name = filename.split(".")[0]
#create a map object from the file
map = arcpy.mapping
map_document = map.MapDocument(file)
#Check for broken data sources
brokenList = arcpy.mapping.ListBrokenDataSources(map_document)
if brokenList:
errorString = filename+" has broken data sources on layer(s): "
for item in brokenList:
errorString = errorString + "'"+item.name+"'"
arcpy.AddError(errorString)
# Set all the parameters as variables here:
data_frame = 'PAGE_LAYOUT'
resolution = "300"
image_quality = "NORMAL"
colorspace = "RGB"
compress_vectors = "True"
image_compression = "DEFLATE"
picture_symbol = 'RASTERIZE_BITMAP'
convert_markers = "TRUE"
embed_fonts = "True"
layers_attributes = "NONE"
georef_info = "False"
#perform selected operations
if yesPDF=="true":
arcpy.AddMessage("Exporting: "+ filename+" as PDF")
out_pdf = outputFolder + os.sep + mxd_name+ ".pdf"
map.ExportToPDF(map_document, out_pdf, data_frame, 640, 480, resolution, image_quality, colorspace, compress_vectors, image_compression, picture_symbol, convert_markers, embed_fonts, layers_attributes, georef_info)
if mergePDF =="true":
combinedpdf.appendPages(out_pdf)
if yesJPG=="true":
arcpy.AddMessage("Exporting: "+ filename+" as JPEG")
out_jpg = outputFolder + os.sep + mxd_name+ ".jpg"
map.ExportToJPEG(map_document, out_jpg)
if yesPNG=="true":
arcpy.AddMessage("Exporting: "+ filename+" as PNG")
out_png = outputFolder + os.sep + mxd_name+ ".png"
map.ExportToPNG(map_document, out_png, data_frame, 640, 480, resolution)
if yesEMF=="true":
arcpy.AddMessage("Exporting: "+ filename+" as EMF")
out_emf= outputFolder + os.sep + mxd_name+ ".emf"
map.ExportToEMF(map_document, out_emf, data_frame, 640, 480, resolution, image_quality, "#", picture_symbol, convert_markers)
if yesAI=="true":
arcpy.AddMessage("Exporting: "+ filename+" as AI")
out_AI= outputFolder + os.sep + mxd_name+ ".ai"
map.ExportToAI(map_document, out_AI)
if yesPRINT=="true":
arcpy.AddMessage("Printing: "+filename)
map.PrintMap(map_document, printer)
del map #delete the map opject
combinedpdf.saveAndClose()
del combinedpdf
# This gives feedback in the script tool dialog
arcpy.GetMessages()
