Hi everyone.
I have an environment of ArcGIS Enterpise 10.6.1, Federate Hosting Server, Portal, Datastore and 2 Webadaptor.
I publish a service from ArcGIS Desktop to ArcGIS Server, and I try to eliminate it from Portal for ArcGIS but I get an error ("Unable to reach the server where the service is. Consider using calling deleteItem with options = { 'force' : true } if the server won't be available anymore")
I can delete items of Dashboard, WebMap, Shapefile and Feature Layer Hosted without problem, but if it is a service that I published from Desktop, I get that error. I followed the instructions of deleteItem with options = { 'force' : true }, and I can eliminate the item without problem.
Apart from this solution, is there a way to delete items from Portal for Arcgis without having to go to Sharing? Any recommendation, idea or suggestion to find the error and a more direct solution?
