Just looking for some clarification on how geocoding works in Pro. I have created a Geocoder based on a point layer of address points. It seems to be working as desired when I type addresses into the 'Locate' window. But when I use the same locator in the Geocode Addresses Geoprocessing tool, the exact same address that I type in the Locate window comes up as 'U' - unmatched.
All of my settings in the Geocoder are set to default. All I did was specify which fields to use for Number, Road Type, etc.
Also, the list of addresses I am geocoding is actually the table of addresses that make up the point layer the geocoder is based on. So I would think I would get a 100% match rate, but I am not.
Any advice on how to tweak my geocoder is appreciated.
Thanks!
