Hi all,
I used thr arcgis api help to create a Closest Facility script.
Find closest facilities | ArcGIS API for JavaScript 3.25
I copied almost the entire code, just changed the facilities and the spatial reference.
I uploaded my network analysis service to my server and it does not work.
Nothing i do make it works. I tried to check if the code from the help section works without my changes but apparently i cant connect the service from my PC, but it does work from the link
https://developers.arcgis.com/javascript/3/samples/routetask_closest_facility/
the log in the script is me trying to see where it went wrong, it seems like the
routeGraphicLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"mouse-over"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok4.3"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//clear existing directions and highlight symbol</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML<SPAN class="operator token">=</SPAN> <SPAN class="string token">"Hover over the route to view directions"</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok4.5"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> highlightSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>SimpleLineSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SOLID<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4.5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> highlightGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN>highlightSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok5"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>highlightGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> esriLang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">substitute</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">,</SPAN><SPAN class="string token">"${*}"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok6"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> and the
<SPAN class="comment token">//solve </SPAN>
closestFacilityTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">solve</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>solveResult<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok7"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>solveResult<SPAN class="punctuation token">.</SPAN>routes<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>route<SPAN class="punctuation token">,</SPAN> index<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//build an array of route info</SPAN>
<SPAN class="keyword token">var</SPAN> attr <SPAN class="operator token">=</SPAN> array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN>solveResult<SPAN class="punctuation token">.</SPAN>directions<SPAN class="punctuation token">[</SPAN>index<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>text<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Attributes"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"${*}"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
route<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN>infoTemplate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
route<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttributes</SPAN><SPAN class="punctuation token">(</SPAN>attr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
routeGraphicLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>route<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Hover over the route to view directions"</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok??"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//display any messages</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>solveResult<SPAN class="punctuation token">.</SPAN>messages<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<b>Error:</b> "</SPAN> <SPAN class="operator token">+</SPAN> solveResult<SPAN class="punctuation token">.</SPAN>messages<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>does not work at all.
can someone maybe point me for what i`m doing wrong?
thanx
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta http<SPAN class="operator token">-</SPAN>equiv<SPAN class="operator token">=</SPAN><SPAN class="string token">"Content-Type"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/html; charset=utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Closest Facilities<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.25%2Fdijit%2Fthemes%2Fclaro%2Fclaro.css" target="_blank">https://js.arcgis.com/3.25/dijit/themes/claro/claro.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.25%2Fesri%2Fcss%2Fesri.css" target="_blank">https://js.arcgis.com/3.25/esri/css/esri.css</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
body<SPAN class="punctuation token">,</SPAN>html<SPAN class="punctuation token">,</SPAN>#main<SPAN class="punctuation token">{</SPAN>margin<SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>padding<SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>height<SPAN class="punctuation token">:</SPAN><SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>width<SPAN class="punctuation token">:</SPAN><SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">.</SPAN>panel <SPAN class="punctuation token">{</SPAN>
border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 6px<SPAN class="punctuation token">;</SPAN>
box<SPAN class="operator token">-</SPAN>shadow<SPAN class="punctuation token">:</SPAN> 0px 6px 3px <SPAN class="operator token">-</SPAN>3px #<SPAN class="number token">888</SPAN><SPAN class="punctuation token">;</SPAN>
border<SPAN class="punctuation token">:</SPAN> 2px solid #86942A<SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> 5px<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fjs.arcgis.com%2F3.25%2F" target="_blank">https://js.arcgis.com/3.25/</A><SPAN>"</SPAN></SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">,</SPAN> params<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"dojo/dom"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/_base/array"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/registry"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/urlUtils"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/lang"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/InfoTemplate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/renderers/SimpleRenderer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Point"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/FeatureSet"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/ClosestFacilityTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/ClosestFacilityParameters"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleMarkerSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/symbols/SimpleLineSymbol"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/form/ComboBox"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/ContentPane"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
dom<SPAN class="punctuation token">,</SPAN> array<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN> parser<SPAN class="punctuation token">,</SPAN> registry<SPAN class="punctuation token">,</SPAN>
urlUtils<SPAN class="punctuation token">,</SPAN> Map<SPAN class="punctuation token">,</SPAN> esriLang<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> InfoTemplate<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> SimpleRenderer<SPAN class="punctuation token">,</SPAN>
Point<SPAN class="punctuation token">,</SPAN> FeatureSet<SPAN class="punctuation token">,</SPAN>
ClosestFacilityTask<SPAN class="punctuation token">,</SPAN> ClosestFacilityParameters<SPAN class="punctuation token">,</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> SimpleLineSymbol
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> incidentsGraphicsLayer<SPAN class="punctuation token">,</SPAN> routeGraphicLayer<SPAN class="punctuation token">,</SPAN> closestFacilityTask<SPAN class="punctuation token">;</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
urlUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addProxyRule</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
urlPrefix<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"route.arcgis.com"</SPAN><SPAN class="punctuation token">,</SPAN>
proxyUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"/sproxy/"</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"streets"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">35.019666588</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">32.773163574</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN>
showInfoWindowOnClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN>
map<SPAN class="punctuation token">.</SPAN>spatialReference <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">2039</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> mapClickHandler<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
params <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClosestFacilityParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>impedenceAttribute<SPAN class="operator token">=</SPAN> <SPAN class="string token">"Length"</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>defaultCutoff<SPAN class="operator token">=</SPAN> <SPAN class="number token">7.0</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>returnIncidents<SPAN class="operator token">=</SPAN><SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>returnRoutes<SPAN class="operator token">=</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>returnDirections<SPAN class="operator token">=</SPAN><SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evtObj<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> evtObj<SPAN class="punctuation token">.</SPAN>target<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> facilityPointSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_SQUARE<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">89</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">95</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">35</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN>
<SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">130</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">159</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">83</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.40</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> incidentPointSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">.</SPAN>STYLE_CIRCLE<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
incidentsGraphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> incidentsRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>incidentPointSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
incidentsGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>incidentsRenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>incidentsGraphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
routeGraphicLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> routePolylineSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleLineSymbol</SPAN><SPAN class="punctuation token">(</SPAN>
<SPAN class="number token">4.0</SPAN>
<SPAN class="keyword token">var</SPAN> routeRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>routePolylineSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
routeGraphicLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>routeRenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>routeGraphicLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> facilitiesGraphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> facilityRenderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN>facilityPointSymbol<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>facilityRenderer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>facilitiesGraphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3898452.00060809</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3866259.95676958</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3898265.94287582</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865871.18883343</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3898503.83466325</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865604.65310533</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3898875.14529586</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865745.2226377</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3899318.62932033</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865316.43084768</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3899233.56541492</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865337.13371146</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3897905.10544874</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865821.03375048</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">3897867.58019902</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">3865713.1500249</SPAN><SPAN class="punctuation token">,</SPAN>map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok1"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> facilities <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureSet</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
facilities<SPAN class="punctuation token">.</SPAN>features <SPAN class="operator token">=</SPAN> facilitiesGraphicsLayer<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>facilities <SPAN class="operator token">=</SPAN> facilities<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>outSpatialReference <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//after map loads, connect to listen to mouse move & drag events</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"mouse-move"</SPAN><SPAN class="punctuation token">,</SPAN> showCoordinates<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"mouse-drag"</SPAN><SPAN class="punctuation token">,</SPAN> showCoordinates<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
closestFacilityTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ClosestFacilityTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2F132.68.130.156%3A6443%2Farcgis%2Frest%2Fservices%2FNetwork%2Fbottle%2FNAServer%2FClosest_Facility" target="_blank">https://132.68.130.156:6443/arcgis/rest/services/Network/bottle/NAServer/Closest_Facility</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok2"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>closestFacilityTask<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
registry<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"numLocations"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"change"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
params<SPAN class="punctuation token">.</SPAN>defaultTargetFacilityCount <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">clearGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">showCoordinates</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//display mouse coordinates</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"info"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN>x <SPAN class="operator token">+</SPAN> <SPAN class="string token">", "</SPAN> <SPAN class="operator token">+</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">clearGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//clear graphics</SPAN>
dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML<SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN>
routeGraphicLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
incidentsGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">clear</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">mapClickHandler</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> inPoint <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> evt<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> location <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN>inPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
incidentsGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>location<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>inPoint<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN> inPoint<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>location<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> incidents <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureSet</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
incidents<SPAN class="punctuation token">.</SPAN>features <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">;</SPAN>
params<SPAN class="punctuation token">.</SPAN>incidents <SPAN class="operator token">=</SPAN> incidents<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok4"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">enableMouseEvents</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok4.2"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ok7.1"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"not good"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"claro"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/BorderContainer"</SPAN>
data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"design:'headline', gutters:false"</SPAN>
style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:100%;height:100%;margin:0px;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN>
data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/layout/ContentPane"</SPAN>
data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'center'"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"panel"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"directions"</SPAN>
data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>props<SPAN class="operator token">=</SPAN><SPAN class="string token">"region:'bottom'"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"panel"</SPAN>
style<SPAN class="operator token">=</SPAN><SPAN class="string token">"height:250px;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>b<SPAN class="operator token">></SPAN>Click the map to find routes <SPAN class="keyword token">for</SPAN> the
<SPAN class="operator token"><</SPAN>select id<SPAN class="operator token">=</SPAN><SPAN class="string token">"numLocations"</SPAN> name<SPAN class="operator token">=</SPAN><SPAN class="string token">"numLocations"</SPAN> data<SPAN class="operator token">-</SPAN>dojo<SPAN class="operator token">-</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">"dijit/form/ComboBox"</SPAN> value<SPAN class="operator token">=</SPAN><SPAN class="string token">"1"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"width:60px;"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option selected<SPAN class="operator token">=</SPAN><SPAN class="string token">"selected"</SPAN><SPAN class="operator token">></SPAN><SPAN class="number token">1</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option<SPAN class="operator token">></SPAN><SPAN class="number token">2</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option<SPAN class="operator token">></SPAN><SPAN class="number token">3</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option<SPAN class="operator token">></SPAN><SPAN class="number token">4</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>option<SPAN class="operator token">></SPAN><SPAN class="number token">5</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>option<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>select<SPAN class="operator token">></SPAN> closest facilities to the input point<SPAN class="punctuation token">.</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>b<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"directionsDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>span id<SPAN class="operator token">=</SPAN><SPAN class="string token">"info"</SPAN> style<SPAN class="operator token">=</SPAN><SPAN class="string token">"position:absolute; left:15px; bottom:5px; color:#000; z-index:50;"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>span<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
