Im developing an web app (a form), and in one textfield i wanna put a Street Search using the example on this web(Search with customization | ArcGIS API for JavaScript ).
I have a secured service that im accesing to get the streets that i wanna search, but for some reason it doesnt work.
Im doing something wrong?
My structure folder is:
The login.js: is used to bypass the IdentityManager and have access to another modules like: capas.js (layers are loaded here), comboComuna.js(the combobox that show some cities) and the search (where i wanna add the code for the Calles(streets) and make a search as showed in the example Search with customization).
And my codes for earch file are:
<!DOCTYPE html>
<html lang="en">
<head>
<title>Bootstrap Example</title>
<meta charset="utf-8">
<meta name="author" content="ehernanr">
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="css/bootstrap.min.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
#map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
#contenedorMapa{
height:600px;
#contenedorBtnGrabar {
vertical-align: middle;
#search {
display: block;
position: absolute;
z-index: 2;
top: 20px;
left: 74px;
</style>
<!-- jQuery library -->
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
<!-- Latest compiled JavaScript -->
<script src="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
<script>var dojoConfig = {parseOnLoad: true,
packages: [
};</script>
<script src="http://js.arcgis.com/3.13/"></script>
<script src="js/login.js"></script>
<script>
var map;
var token;
var esriId;
var valorComuna = document.getElementById("id_comuna_dmps");
require(["esri/map",
"dojo/parser",
"esri/IdentityManager",
"dojo/domReady!" ],
function(Map,parser,IdentityManager) {
parser.parse();
esriId = IdentityManager;
map = new Map("map", {
basemap: "topo",
center: [-71.0659,-32.9252], // long, lat
zoom: 8
//valida login
map.onload(validate());
</script>
</head>
<body data-spy="scroll" data-target="form-group" >
<div class="container-fluid">
<h1>PMS</h1>
<div class="panel-group">
<div class="panel panel-default">
<div class="panel-body">
<form class="form-inline" role="form">
<div class="form-group">
<label for="email">COMUNA</label>
<select id="id_comuna_dmps"><option value="" >Seleccione una Comuna</option></select>
</div>
<label>CALLE:</label>
<!-- <input type="text" class="form-control" id="gl_nombre_calle" size="20" maxlength="30" /> -->
<div id="search"></div>
</div>
<label>PREFIJO:</label>
<input type="text" class="form-control" id="gl_num_prefijo" size="2" maxlength="4" />
</div>
<label>NUMERO:</label>
<input type="text" class="form-control" id="nr_municipal" size="4" maxlength="6" />
</div>
<label>SUFIJO:</label>
<input type="text" class="form-control" id="gl_num_sufijo" size="2" maxlength="4" />
</div>
<label>ID DIRECCION:</label>
<input type="text" class="form-control" id="id_direccion" size="6" />
</div>
<button type="submit" class="btn btn-default">Validar Direccion</button>
</div>
</form>
</div>
</div>
<label for="email">BUSCAR:</label>
<select name="lstTipoElemento" id="lstTipoElemento" class="form-control">
<option value="camara">CAMARA</option>
<option value="poste" selected="selected">POSTE</option>
<option value="nis">NIS</option></select>
</div>
<div class="form-group"><input name="txtValorBusqueda" type="text" id="txtValorBusqueda" class="form-control" size="60" maxlength="80"></div>
<div class="form-group"><input name="button" type="button" value="Buscar" class="btn btn-default"></div>
<div class="form-group"><input name="button2" type="button" value="Manual" class="btn btn-default"></div>
</form>
</div>
</div>
</div>
<div class="panel panel-default"><div class="panel-body" id="contenedorMapa"><div id="map"> </div></div></div>
<div class="panel panel-default"><div class="panel-body"><div class="form-group" id="contenedorBtnGrabar"><input name="button" type="button" value="Grabar" class="btn btn-default"></div></div></div>
</div> <!-- panel group -->
</body>
</html>login.js:
function validate() {
var username = 'myusername';
var password = 'mypassword';
var http = new XMLHttpRequest();
var url = "myrestsrv/arcgis/tokens/generateToken";
var str1 = "username=";
var str2 = "&password=";
var str3 = "&f=json&client=requestip&expiration=1440";
var params = str1.concat(username, str2, password, str3);
//f="json", client="requestip", expiration="1440"
http.open("POST", url, true);
http.setRequestHeader("Content-type", "application/x-www-form-urlencoded");
http.setRequestHeader("Content-length", params.length);
http.setRequestHeader("Connection", "close");
http.onreadystatechange = function () {
if (http.readyState == 4 && http.status == 200) {
var tokenRespuesta = http.responseText;
token=JSON.parse(tokenRespuesta);
if (tokenRespuesta.search("error") == -1) {
esri.id.registerToken(
{server: 'http://myRestSrv/arcgis/rest/services',
userId: 'userejemplo',
token: token.token,
expires: token.expires,
ssl: false
//HABILITAR MODULOS Y COMBOS UNA VEZ HECHO EL LOGIN
dojo.registerModulePath("capas", "http://127.0.0.1:8020/PMS/js/capas");
dojo.require('capas');
dojo.registerModulePath("comboComuna", "http://127.0.0.1:8020/PMS/js/comboComuna");
dojo.require('comboComuna');
dojo.registerModulePath("mySearch", "http://127.0.0.1:8020/PMS/js/mySearch");
dojo.require('mySearch');
} else {
alert("Login incorrecto, intente nuevamente.");
http.send(params);
return false;
}comboComuna.js
require([
"dojo/dom",
"esri/tasks/query", "esri/tasks/QueryTask","dojo/domReady!"
], function (dom, Query, QueryTask) {
var queryTask = new QueryTask("myRestSrv/arcgis/rest/services/Chilquinta_006/Equipos_pto_006/MapServer/0");
var query = new Query();
query.returnGeometry = false;
query.outFields = ["nombre"];
query.where= "1=1";
queryTask.execute(query, showResults);
function showResults (results) {
document.getElementById("id_comuna_dmps").innerHTML = "";
var submenu = new Array();
var resultItems = [];
var resultCount = results.features.length;
var x = document.getElementById("id_comuna_dmps");
for (var i = 0; i < resultCount; i++) {
var featureAttributes = results.features.attributes;
for (var attr in featureAttributes) {
var c = document.createElement("option");
c.text = featureAttributes[attr];
x.options.add(c, attr);
//resultItems.push("<br>");
}//showresults
});capas.js
require([
"esri/map", "esri/InfoTemplate", "esri/layers/FeatureLayer",
"dojo/parser" , "dojo/domReady!"
], function(Map, InfoTemplate, FeatureLayer, parser) {
parser.parse();
var fLayerDist = new FeatureLayer("myRestSrv/arcgis/rest/services/PMS/Concesiones/MapServer/1",{
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
var fLayerTrans = new FeatureLayer("myRestSrv/arcgis/rest/services/PMS/Concesiones/MapServer/0",{
outFields: ["*"],
var fLayerComuna = new FeatureLayer("myRestSrv/arcgis/rest/services/MANTENIMIENTO/MANTENIMIENTO_PODAS/FeatureServer/0", {
outFields: ["*"]
map.addLayers([fLayerDist,fLayerTrans,fLayerComuna]);
// map.addLayer(fLayerComuna);
});mySearch.js
require([
"esri/map",
"esri/dijit/Search",
"dojo/domReady!"
], function (Map, FeatureLayer, Search, InfoTemplate) {
//Create search widget
var search = new Search({
map: map,
sources: [],
zoomScale: 5000000
}, "gl_nombre_calle");
//listen for the load event and set the source properties
search.on("load", function () {
var sources = search.sources;
sources.push({
featureLayer: fLayerComuna,
placeholder: "123",
enableLabel: false,
searchFields: ["CODIGO_SAP"],
displayField: "CODIGO_SAP",
exactMatch: false,
outFields: ["*"],
//Create an InfoTemplate and include three fields
infoTemplate: new InfoTemplate("Ecological Footprint", "<a href= ${URL} target=_blank ;'>Additional Info</a></br></br>Country: ${Country}</br>Rating: ${Rating}")
//Set the sources above to the search widget
search.set("sources", sources);
search.startup();
});Thanks in advice
Mensaje editado por: Evelyn Hernandez Updated with the search.set("sources", sources);
