We use the measure tool to show intermediate segment values and then the total value. Has the setting of the single mouse click and the double mouse click changed? Has the setting of the mouse-move changed? The mouse events seem to be affected by the GeometryService changes or arcgisonline change that occurred last week.
For example, when using our internal Geometry Service,
or this URL: utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer,
or this URL: tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer
our code keeps returning values as though the mouse is still moving after double-clicking on the map to end the polyline measurement. For example, each mouse click adds "Segment". Each mouse-move displays both "Total Length" and "Current Length". A double-mouse click removes the "Total Length" and "Current Length" and then adds the final "Total Length". However, the problem is that after the double-mouse click, the first "Total Length" and "Current Length" stay and the two numbers keep changing randomly even though the mouse isn't moving. After a while (3 to 15 seconds), the random numbers stop.
.png)
When using the URL tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer,
The problem appears to start after the following lines of code are executed:
map.graphics.clear();
undoManager.clearRedo();
undoManager.clearUndo();
When using the other two URLs, the problem may occur right away or after clearing the all the graphics. Note: I cleared my browser cache between tests. If I don't clear the cache, then once the problem starts it persists.
A secondary problem:
The double-mouse click registers as a single-mouse click, and adds an extra "Segment" line as show above. In the example above, I double-clicked on the map to end the line at Segment 3, but Segment 4 was added with a slightly higher length than segment 3.
This code has been working for a long time, and is still using API version 3.16. Is this version still being supported, or has something changed?
