Hi
I found this Code by Yanli Zhang, Stephen F. Austin State University online
I am not familiair with python but this script is exactly what I need, except that I do not have years but attribute names like WRBDeAA01 or WNHDeAA51 (list of attribute names)
How do I have to change the loop so the code runs through these attributes instead of years?
import arcpy, os
#Specify the map document and the data frame
mxd = arcpy.mapping.MapDocument(r"C:\temp\pine.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "layers")[0]
outPath = r"C:\temp\output\\" #output file folder
#Year (2004, 2003, ...) is used as attribute field name
#Also it is used to control the loop
year = 2004
while year >= 1860: # 1860 is the last year in the attribute table
for maplayer in arcpy.mapping.ListLayers(mxd):
if maplayer.name == "Pine":
#chang the symbology
if maplayer.symbologyType == "GRADUATED_SYMBOLS":
maplayer.symbology.valueField = str(year)
maplayer.symbology.classBreakValues = [0, 20.0, 30.0, 40.0, \
50.0, 60.0, 70.0, 80.0, \
90.0, 100.0, 110.0, 120.0, \
130.0, 140.0, 150.0]
maplayer.symbology.classBreakLabels = ["0 to 19.99", "20 to 29.99", "30 to 39.99", \
"40 to 49.99", "50 to 59.99", "60 to 69.99", \
"70 to 79.99", "80 to 89.99", "90 to 99.99", \
"100 to 109.99", "110 to 119.99", \
"120 to 129.99", "130 to 139.99", \
"140 to 150"]
# Change title for each map
for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT"):
if elm.text.find("Plot 4 Year")>= 0:
elm.text = "Plot 4 Year " + str(year)
#export each map as a jpeg file. Also we can use ExportToPDF method.
nameJPEG = outPath + str(year) + ".jpg" #spedify each output file name
arcpy.mapping.ExportToJPEG(mxd, nameJPEG)
year = year - 1
del mxd, df
