I've been using code like the extract below to test whether a lot is on a corner (i.e. has two streetwidth variables greater than 0).Is there a better way to do this? I know you can create LotCorners but these are triangular lots that I don't want.Lot -->
setback(0.1) {streetSide: nil | remainder : test(comp.index)}
test(compIndex) -->
case streetWidth(0) > 0 && streetWidth(1) > 0 : building
case streetWidth(0) > 0 && streetWidth(2) > 0 : building
case streetWidth(0) > 0 && streetWidth(3) > 0 : building
case streetWidth(1) > 0 && streetWidth(1) > 0 : building
case streetWidth(1) > 0 && streetWidth(2) > 0 : building
case streetWidth(1) > 0 && streetWidth(3) > 0 : building
case streetWidth(2) > 0 && streetWidth(1) > 0 : building
case streetWidth(2) > 0 && streetWidth(2) > 0 : building
case streetWidth(2) > 0 && streetWidth(3) > 0 : building
case streetWidth(3) > 0 && streetWidth(1) > 0 : building
case streetWidth(3) > 0 && streetWidth(2) > 0 : building
case streetWidth(3) > 0 && streetWidth(3) > 0 : building
else : nil
building-->
offset(-2, inside)
extrude(rand(3,15))
