I am populating an array that contains fields and labels that will be used in a data grid. I am working with the ESRI sample, and I am trying to change the width of the columns for each attribute, but have not had any luck.
Here is the block of code:
var columns = [
{'field': 'PARCELID', 'label': "Parcel ID"},
{'field': 'OWNERNME1', 'label': 'Owner 1'},
{'field': 'OWNERNME2', 'label': 'Owner 2'},
{'field': 'RESYRBLT', 'label': 'Year Built'},
{'field': 'SITEADDRESS', 'label': 'Street Address', 'width': '50'}
The fields all remain the same width within the application. I am testing with this sample:
Here is the sample I am looking at:
Display Find Task results in Dojo DataGrid
I just cannot get the column widths to change. Anyone have any ideas?
Thanks!
