We are using Arcgis Runtime SDK for Qt 10.2.6 and Qt 5.4.2 (MSVC 2013, 32 bit) Qt Creator QT\QML side .We have local editing application which edits features within an offline geodatabase and sync back to the service.We are using GeodatabaseSyncTask class's generateGeodatabase (GenerateGeodatabaseParameters parameters, string filename) method to generate geodatabase.
Can I generate geodatabese using without GenerateGeodatabaseParameters's extent property ? can I generate using only layerIds or layerQueries properties ?
I'm tried to generate witout extent propery with using only layerIds and layerQueries but when I can not generate , here is the console output below:
D/MaksMobil(30477): qrc:/qml/MapNumarataj.qml:291 (onGenerateStatusChanged): qml: Generate Error messageFailed to parse geometry from input JSONcode400
Best Regards
