Is there a way to default Get parametersAsTest
Where when I run the tool it will be defaulted unless the user changes it.
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
sde_conn <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">or</SPAN> <SPAN class="string token">"C:\Users\xyz\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog\x@x.sde"</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
