Hi All,
I have two Polygon layers, one is "Land Parcels", and the other one is "Central Business District (CBD)".
Someone has asked me to provide a map showing the CBD area, color the properties within the CBD area Red, and all other properties blue.
I know I can do a simple select by location, export a feature class of CBD properties and color this way, but as this property layer changes daily I would like this map to be dynamic. So each time I open the MXD the map is up-to-date.
See attached area and two Feature Classes.
Adding a field is not an option unfortunately.
Any suggestions? Im not good at thinking outside the box.
I should also note that this plan will need to be updated and re-distributed every month, hence my automation request, rather than the export feature class workflow.
Cheers
