In NYS we have a custom ESRI geocoding service that can geocode to rooftop level accuracy, and I am trying to use for batch geocoding in a Jupyter notebook using python. However when I attempt to perform a batch_geocode operation I am not convinced that the address is being sent to the NYS service rather than the ESRI universal geocoding service. Here is my code:
In [1]: # Import the necessary libraries
from arcgis.gis import GIS
from arcgis.geocoding import Geocoder, get_geocoders, batch_geocode, geocode
In [2]: #Set custom ESRI geocoding service url to the NYS Geocoding Service
nys_gcdr_url = 'Locators/Street_and_Address_Composite (GeocodeServer) '
In [3]: #Establish my connection to ArcGIS Online and set the preferred geocoder to the NYS geocoder
gis = GIS("http://www.arcgis.com", "username", "password")
esrinl_geocoder = Geocoder(nys_gcdr_url, gis)
esrinl_geocoder
Out [3]: <Geocoder url:"https://gisservices.its.ny.gov/arcgis/rest/services/Locators/Street_and_Address_Composite/GeocodeServe r">
In [4]: addresses = ["80 South Swan Street, Albany, NY, 12201",
"10 B Airline Drive, Albany, NY, 12205",
"800 North Pearl Street, Albany, NY, 12204",
"5826 Fayetteville Rd, Durham, NC 27713"]
In [6]: results = batch_geocode(addresses, esrinl_geocoder)
In [7]: for result in results:
print("Score " + str(result['score']) + " : " + result['address'])
Out [7]:
Score 99.52 : 80 S Swan St, Albany, New York, 12210 Score 100 : 10 Airline Dr, Albany, New York, 12205 Score 100 : 800 N Pearl St, Albany, New York, 12204 Score 100 : 5826 Fayetteville Rd, Durham, North Carolina, 27713
In [8]: results[1]['location']
Out [8]: {'x': -73.81899493299994, 'y': 42.73686765800005}
My issue...
From what I can gather, the gis = GIS() in Input [3]: establishes a connection to ArcGIS Online using my developer account credentials. Even though I set the Geocoder to the NYS geocoder url with esrinl_geocoder, I’m wondering which geocoder is actually being used? The results/scores I output in the code are higher than I expect them to be, for example I get a score of 95.0 when I run the first address against the NYS geocoder here (Find Address Candidates: (Locators/Street_and_Address_Composite) ). Also the x,y for the address vary based on method:
{'x': -73.81899493299994, 'y': 42.73686765800005} for ESRI Python and {'x': -73.75989873712614, 'y': 42.654069473771784} for NYS GeocoderIn addition, the North Carolina address should not provide a match against the NYS geocoder, however it returns a score of 100 in Out [7].
So:
1) Does the batch_geocode operation default to the ESRI Geocoder despite the custom geocoder url being set with esrinl_geocoder?
2) Are there certain circumstances when this occurs, such as the ESRI geocoder kicks in when a match cannot be returned with the specified geocoder (e.g.; NC address)?
Thanks for any insight!
