Hello All,
I am curious if anyone is having similar issues as I am with Pro 2.0. Has anyone else experienced any of the following:
1. projects crashing
2. definition queries are splitting clause values (ie 'Doe, John' becomes 'Doe', 'John') I seem to be having alot of issues with Pro deciding what I want my IN queries to be - it will overwrite what I enter if I use the SQL window or the clauses
3. Projects becoming inaccessible and not opening - receiving an error window "ArcGIS Pro has stopped working..." Usually if I restore the last saved back up it fixes the problem, but obviously this is not an appropriate work around and causes loss of work and time. Ive had this issue with 2 projects so far.
Please share if you've had have similar issues or advice. Thanks!
