Hi!So I wrote some Python code to List all Maps in a folder and some more properties and stuff. Everything keeps running perfectly smooth if I use it in the ArcmapGeoprocessing/Python Command Window.But if I want to run it as a Script it fails. Giving me this Error message<class 'arcgisscripting.ExecuteError'>: Failed to execute. Parameters are not valid.
ERROR 000732: Input Table: Dataset MXD_Overview_Table does not exist or is not supported
Failed to execute (AddField).
The new table (MXD_Overview_Table) is created, but for some reason Python can not add fields if running as a script. What is it I am missing?Thanks for your helpChrisP.S: I ve Windows 7 for 64 bit, ARCGIS10 Editor Licence with Service Pack 2 installed, on a Dell with a Intel i 7 and 8GB of Ram and plenty of space on my harddisk.My Code is:#List all maps and there properties in a folder
# Import system modules
import arcpy, os, glob
import sys
import traceback
# Overwrite pre-existing files
#This is the folder containing your MXD's
arcpy.env.workspace = r"P:/RAME/GIS/2011/Maps" #arcpy.GetParameterAsText(0)
baseFolder=arcpy.env.workspace
#The Geodatabase to store the Resulting table in
geoDataBasePath="P:/RAME/GIS/2011/RAME.gdb" #arcpy.GetParameterAsText(1)
#The Name of the New Table containing the MXD-List
NewTable="MXD_Overview_Table" #arcpy.GetParameterAsText(2)
#Define Workspace
#Create New Lists for Layers and Sources of Layers
mxdFileNames=[]
workspaces=[baseFolder]
#Create a new table containing Name of MXD, Path of MXD, Selected MXD Properties, Layers in the MXD and Sources (Shapefiles on which the Layers are based of the MXD)
field_length=255
field_length2=3000
arcpy.CreateTable_management(geoDataBasePath, NewTable)
arcpy.AddField_management(NewTable, "MXD_Name", 'TEXT', '', '', field_length, "MXD_Name")
arcpy.AddField_management(NewTable, "MXD_Path", 'TEXT', '', '', field_length, "MXD Fullpath")
arcpy.AddField_management(NewTable, "Author", 'TEXT', '', '', field_length, "Authors of MXD")
arcpy.AddField_management(NewTable, "Credits", 'TEXT', '', '', field_length, "Credits")
arcpy.AddField_management(NewTable, "Descript", 'TEXT', '', '', field_length2, "Map Description")
arcpy.AddField_management(NewTable, "Summary", 'TEXT', '', '', field_length2, "Map Summary")
arcpy.AddField_management(NewTable, "Tags", 'TEXT', '', '', field_length, "Map Tags")
arcpy.AddField_management(NewTable, "Saved", 'TEXT','','',field_length2,"Date Saved")
arcpy.AddField_management(NewTable, "Layers", 'TEXT', '', '', field_length2,"Layers included in Map")
arcpy.AddField_management(NewTable, "FeatureCl", 'TEXT', '', '', field_length2, "Featureclasses included in Map")
#Lets grab a listing of all MXD's in our workspace; baseFolder
b = arcpy.ListWorkspaces("*", "Folder")
workspaces.extend(b)
for workspace in workspaces:
allItems = os.listdir(workspace)
# filter out just .mxd's
mxdFileNames = [(x) for x in allItems if x.endswith('.mxd')]
#For each mxd get all parameters. To do this step through the mxd list
for name in mxdFileNames:
try:#get mxd
arcpy.env.workspace=baseFolder
temp= str(str("%s" %workspace)+"\\"+name)
mxd = arcpy.mapping.MapDocument(temp)
namemxd= str("%s" % mxd.title)
filePath=str(mxd.filePath)
author="%s" % mxd.author
credits_="%s" % mxd.credits
dateSaved="%s" % mxd.dateSaved
description="%s" % mxd.description
summary="%s" % mxd.summary
tags="%s" % mxd.tags
#list all the layers for MXD after another from above
try:
Source=[]
LyrList=[]
mxdlyrs=arcpy.mapping.ListLayers(mxd)
for lyr in mxdlyrs:
name=lyr.longName
if lyr.supports("dataSource"):
dataSource=lyr.dataSource
else:
dataSource="Not defined"
LyrList.extend([str(name)])
Source.extend([str(dataSource)])
except ValueError:
#get error message if there is a problem getting lyr name or lyr source
print "Invalid Layer in MXD:",filePath,"."
arcpy.AddError( 'Invalid Layer in MXD:',filePath, '. Maybe because of a missing template.')
finally:
#Create a Insert Cursor to insert new rows and write each value in the corresponding field
cursor = arcpy.InsertCursor(geoDataBasePath+"\\"+NewTable)
row = cursor.newRow()
row.MXD_Name=str(namemxd)
row.MXD_Path=str(filePath)
if len(LyrList)>3000:
LyrList=["More than 3000 characters. To many to be written to the file"]
else:
row.Layers=str(LyrList)
if len(Source)>3000:
Source=["More than 3000 characters. To many to be written to the file"]
else:
row.FeatureCl=str(Source)
row.Author=author
row.Credits=str(credits_)
row.Descript=str(description)
row.Saved=str(dateSaved)
row.Summary=str(summary)
row.Tags=str(tags)
cursor.insertRow(row)
# tidy up
del row
del cursor
except ValueError:
print "Invalid MXD:",filePath,". Open the mxd in ArcMap and check for errors."
arcpy.AddError( 'Invalid MXD:',filePath, '. Open the mxd in ArcMap and check for errors.')
