What I want to do seems fairly straightforward. I have a dataset with 11 months of data. I want to display each month as a heat map and then run through them to show the shifting of hot spot locations. I created a keyframe for each month but when I press Play, nothing displays except at the end, the last frame. I've played with timing, holds but nothing seems to work. I thought maybe it was taking too long to draw so I moved everything local, that didn't help. I created .tifs thinking that might help but that didn't work either. I also tried creating an animation from the time slider but I cannot get the symbology to look the same. Anyone have any suggestions? thanks!
