Global variables seem to draw the scorn if not ire of most python developers, and recently I've been faced with a situation where creating a variable in a series of defs needs to be passed back to main(). I did a little searching with my friend and associate Dr. Google and found a stack over flow thread which gave me an idea.
In the script I'm (re) writing, I'd like to follow the form of defining my defs() and then calling them from main(). However, each of my defs() use a try/except block, and if there is an exception anywhere along the line I need to abort the final processing.
This is what I came up with in concept:
errorList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">first</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#some code</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
errorList<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">second</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#some other code</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
first<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
second<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> len<SPAN class="punctuation token">(</SPAN>errorList<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># final operations</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># don't execute final operations </SPAN>
main<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Pretty simple concept right?
Taking it one step further, I started thinking how about this:
def1List <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
def2List <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">one</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#blah,blah</SPAN>
append def1List<SPAN class="punctuation token">(</SPAN>someValueFromBlah<SPAN class="punctuation token">)</SPAN>
append def1List<SPAN class="punctuation token">(</SPAN>anotherValueFromBlah<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">two</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># blah2 blah2</SPAN>
append def2List<SPAN class="punctuation token">(</SPAN>someValueFromBlah2<SPAN class="punctuation token">)</SPAN>
append def2List<SPAN class="punctuation token">(</SPAN>anotherValueFromBlah2<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">three</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> def1List<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> myTargetValue<SPAN class="punctuation token">:</SPAN>
do something
<SPAN class="keyword token">elif</SPAN> defList<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">==</SPAN> myOtherTargetValue<SPAN class="punctuation token">:</SPAN>
do something <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
myValue <SPAN class="operator token">=</SPAN> def2List<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
myOtherValue <SPAN class="operator token">=</SPAN> def2List<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># use myValue and MyOtherValue as I need to...</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>These look like they'll work for me in a number of different applications, but I'd like to here from you (and you know who you are) as to whether or not these are:
Good Practice
Bad Practice
Something everybody does already
Etc
Etc....
