Hi,I am having trouble changing the popup title of a webmap feature layer as shown here.The code below demonstrates creation of a new infoTemplate, setting a title function (or string for that matter) and applying the infoTemplate to the feature layer results in an empty title. Setting the popup content works, but not the title.<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
<style type="text/css">
html,body { height:100%; width:100%; margin:0; padding:0; }
body{ background-color:#777; overflow:hidden; font-family:"Trebuchet MS"; }
#map { overflow:hidden; padding:0; }
</style>
<script type="text/javascript">var dojoConfig={parseOnLoad: true};</script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2">
</script>
dojo.require("dijit.dijit"); // optimize: load dijit layer
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.arcgis.utils");
var map;
function init() {
var webmap = "1a40fa5cc1ab4569b79f45444d728067";
var mapDeferred = esri.arcgis.utils.createMap(webmap, "map", {
mapOptions: {
slider: false,
nav:false
mapDeferred.addCallback(function(response) {
map = response.map;
//resize the map when the browser resizes
dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
template = new esri.InfoTemplate();
template.setTitle(function(){ return "i set the title" });
template.setContent(function(){ return "i can set the content, but not the title
var layer = map.getLayer(map.graphicsLayerIds[0]);
layer.setInfoTemplate(template)
mapDeferred.addErrback(function(error) {
console.log("Map creation failed: ", dojo.toJson(error));
function resizeMap() {
var resizeTimer;
clearTimeout(resizeTimer);
resizeTimer = setTimeout(function() {
map.resize();
map.reposition();
}, 500);
//show map on load
dojo.addOnLoad(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"
style="width: 100%; height: 100%; margin: 0;">
<div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
<div id="bingLogo" style="position: absolute;bottom: 2px;left: 3px;display:none;z-index:49;">
<img src="images/bing_logo.png" border="0" />
</div>
</div>
</div>
</body>
</html>�??
