I'm unable to get a workspace from an sde connection and assign the pFeatureWorkspace to it. Here's the VB code:
Dim factoryType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory")
Dim pWorkspaceFactory As IWorkspaceFactory2
Dim pFeatureWorkspaceA As IFeatureWorkspace
Dim pFeatureWorkspaceB As IFeatureWorkspace
Dim featureWorkspace As ESRI.ArcGIS.Geodatabase.IFeatureWorkspace
‘thePropSet, theWorkspace, fimWorkspace, fimPropSet are global variables
Try
pWorkspaceFactory = CType(Activator.CreateInstance(factoryType), IWorkspaceFactory)
'ReadConnectionPropertiesFromFile
theWorkspace = pWorkspaceFactory.OpenFromFile(theFilesLoc & "dnrgdrs-prod1-pg-dc-pfmm_dev.sde", 0)
thePropSet = theWorkspace.ConnectionProperties
fimWorkspace = pWorkspaceFactory.OpenFromFile(theFilesLoc & "\FOR01-ORA-DC-LRSDB-FIM-DEFAULT.sde", 0)
fimPropSet = fimWorkspace.ConnectionProperties
‘Both of these give empty results
pFeatureWorkspaceA = CType(theWorkspace, IFeatureWorkspace)
pFeatureWorkspaceB = CType(fimWorkspace, IFeatureWorkspace)
The pFeatureWorkspace is always empty. The database has data, but somehow it can't find it.
When debugging, I get "No children available"
Thank you for any advice.
