I have changed a variable that used to be supportId for streetSigns and supports, but I needed to separate the values for querying purposes. I am supposed to be able to click on the sign layer and my form should open, but it does nothing. Any ideas?
Here is the click event code:
/* Update Sign Layer Begin */
app.signLayer.on("click", function (evt) {
var installed, signId, facing, visibility, condition, text, color1, delineator, illum, offset;
var mountht, backing, width, height, txtSize, numSize, comments, twoSided, attachType, attachNum, attachLoc, siteObs, signShape, color2, mutcd;
var signObjectId;
signObjectId = evt.graphic.attributes.OBJECTID;
mutcd = evt.graphic.attributes.MUTCD;
installed = evt.graphic.attributes.INSTALLED;
signId = evt.graphic.attributes.SIGNID;
facing = evt.graphic.attributes.FACING;
visibility = evt.graphic.attributes.VISIBILITY;
condition = evt.graphic.attributes.CONDITION_;
signSupportId = evt.graphic.attributes.SUPPORTID;
text = evt.graphic.attributes.TEXT;
color1 = evt.graphic.attributes.COLOR1;
delineator = evt.graphic.attributes.DELINEATOR;
illum = evt.graphic.attributes.ILLUM;
offset = evt.graphic.attributes.OFFSET;
mountht = evt.graphic.attributes.MOUNTHT;
backing = evt.graphic.attributes.BACKING;
width = evt.graphic.attributes.WIDTH;
height = evt.graphic.attributes.HEIGHT;
txtSize = evt.graphic.attributes.TXTSIZE;
numSize = evt.graphic.attributes.NUMSIZE;
comments = evt.graphic.attributes.COMMENTS;
twoSided = evt.graphic.attributes.TWOSIDED;
attachType = evt.graphic.attributes.ATTACHTYPE;
attachNum = evt.graphic.attributes.ATTACHNUM;
attachLoc = evt.graphic.attributes.ATTACHLOC;
siteObs = evt.graphic.attributes.SITEOBS;
signShape = evt.graphic.attributes.SIGNSHAPE;
color2 = evt.graphic.attributes.COLOR2;
// Clear form of values before connecting current values
document.getElementById("signForm").reset();
/* Enter your domain item and then the element to populate */
populateSelect("MUTCD", "mutcd", "sign");
populateSelect("VISIBILITY", "visibility", "sign");
populateSelect("CONDITION_", "condition", "sign");
populateSelect("COLOR1", "color1", "sign");
populateSelect("DELINEATOR", "delineator", "sign");
populateSelect("ILLUM", "illum", "sign");
populateSelect("BACKING", "backing", "sign");
populateSelect("ATTACHTYPE", "attachType", "sign");
populateSelect("ATTACHLOC", "attachLoc", "sign");
populateSelect("SITEOBS", "siteObs", "sign");
populateSelect("SIGNSHAPE", "signShape", "sign");
populateSelect("COLOR2", "color2", "sign");
/* Populate form with data */
document.getElementById("signObjectId").value = signObjectId;
document.getElementById("mutcd").value = mutcd;
document.getElementById("installed").value = installed;
document.getElementById("signId").value = signId;
document.getElementById("facing").value = facing;
document.getElementById("visibility").value = visibility;
document.getElementById("condition").value = condition;
document.getElementById("signSupportId").value = signSupportId;
document.getElementById("text").value = text;
document.getElementById("color1").value = color1;
document.getElementById("delineator").value = delineator;
document.getElementById("illum").value = illum;
document.getElementById("offset").value = offset;
document.getElementById("mountht").value = mountht;
document.getElementById("backing").value = backing;
document.getElementById("width").value = width;
document.getElementById("height").value = height;
document.getElementById("txtSize").value = txtSize;
document.getElementById("numSize").value = numSize;
document.getElementById("signComments").value = comments;
document.getElementById("twoSided").value = twoSided;
document.getElementById("attachType").value = attachType;
document.getElementById("attachNum").value = attachNum;
document.getElementById("attachLoc").value = attachLoc;
document.getElementById("siteObs").value = siteObs;
document.getElementById("signShape").value = signShape;
document.getElementById("color2").value = color2;
if (app.supportLayer.visible == true) {
document.getElementById("btnSignPrevious").style.visibility = "visible";
document.getElementById("btnSignNext").style.visibility = "visible";
} else {
// url the query task is to be performed on
var query = new esriQuery();
var queryTask = new QueryTask(config.signLayerUrl);
// count related records
query.where = "SUPPORTID = " + signSupportId;
// display number of related records in console
queryTask.executeForCount(query, function (count) {
console.log(count);
if (count > 1) {
} else {
document.getElementById("btnSignPrevious").style.visibility = "hidden";
document.getElementById("btnSignNext").style.visibility = "hidden";
document.getElementById("btnSignUpdate").style.visibility = "visible";
// Show signs form for updating
app.attributesSignModal.modal("show");
ii = -1;
/* Update Sign Layer End */And here is the HTML form that it is supposed to open:
<!-- Attributes Sign Modal Begin -->
<form id="signForm">
<div id="attributesSignModal" class="modal fade" style="display: none;" aria-hidden="true">
<!-- Modal Dialog Begin -->
<div class="modal-dialog">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-hidden="true">Ã</button>
<h4 class="modal-title">Add/Edit Sign</h4>
</div>
<div class="modal-body">
<div class="form-group">
<label for="signObjectId">Object ID</label>
<input type="number" class="form-control" name="signObjectId" id="signObjectId" readonly>
</div>
<!-- Mutcd Begin -->
<label for="mutcd">MUTCD</label>
<select id="mutcd" class="form-control" name="mutcd" required></select>
</div>
<!-- Mutcd End -->
<!-- - Begin -->
<label for="installed">Installed</label>
<input type="date" class="form-control" name="installed" id="installed" />
</div>
<!-- Installed End -->
<!-- Sign ID Begin -->
<label for="signId">Sign ID</label>
<input type="number" class="form-control" placeholder="Sign ID" name="signId" id="signId" />
</div>
<!-- Sign ID End -->
<!-- Facing Begin -->
<label for="facing">Facing</label>
<input type="text" class="form-control" placeholder="Facing" name="facing" id="facing" />
</div>
<!-- Facing End -->
<!-- Visibility Begin -->
<label for="visibility">Visibility</label>
<select id="visibility" class="form-control" name="visibility" required></select>
</div>
<!-- Visibility End -->
<!-- Condition Begin -->
<label for="condition">Condition</label>
<select id="condition" class="form-control" name="condition" required></select>
</div>
<!-- Condition End -->
<!-- Support ID Begin -->
<label for="signSupportId">Support ID</label>
<input type="number" class="form-control" name="signSupportId" id="signSupportId" />
</div>
<!-- Support ID End -->
<!-- Text Begin -->
<label for="text">Text</label>
<input type="text" class="form-control" name="text" id="text" />
</div>
<!-- Text End -->
<!-- Color 1 Begin -->
<label for="color1">Color 1</label>
<select id="color1" class="form-control" name="color1" required></select>
</div>
<!-- Color 1 End -->
<!-- Delineator Begin -->
<label for="delineator">Delineator</label>
<select id="delineator" class="form-control" name="delineator" required></select>
</div>
<!-- Delineator End -->
<!-- Illum Begin -->
<label for="illum">Illum</label>
<select id="illum" class="form-control" name="illum" required></select>
</div>
<!-- Illum End-->
<!-- Offset Begin -->
<label for="offset">Offset</label>
<input type="text" class="form-control" name="offset" id="offset" />
</div>
<!-- Offset Ends -->
<!-- Mountht Begin -->
<label for="mountht">MOUNTHT</label>
<input type="text" class="form-control" name="mountht" id="mountht" />
</div>
<!-- Mountht End -->
<!-- Backing Begin -->
<label for="backing">Backing</label>
<select id="backing" class="form-control" name="backing" required></select>
</div>
<!-- Backing End -->
<!-- Width Begin -->
<label for="width">Width</label>
<input type="text" class="form-control" name="width" id="width" />
</div>
<!-- Width End -->
<!-- Height Begin -->
<label for="height">Height</label>
<input type="text" class="form-control" name="height" id="height" />
</div>
<!-- Height End -->
<!-- Txt Size Begin -->
<label for="txtSize">Text Size</label>
<input type="text" class="form-control" name="txtSize" id="txtSize" />
</div>
<!-- Txt Size End -->
<!-- Num Size Begin -->
<label for="numSize">Numsize</label>
<input type="text" class="form-control" name="numSize" id="numSize" />
</div>
<!-- Num Size End -->
<!-- Comments Begin -->
<label for="signComments">Comments</label>
<input type="text" class="form-control" name="signComments" id="signComments" />
</div>
<!-- Comments End -->
<!-- Two Sided Begin -->
<label for="twoSided">Two Sided</label>
<input type="text" class="form-control" name="twoSided" id="twoSided" />
</div>
<!-- Two Sided End -->
<!-- Attach Type Begin -->
<label for="attachType">Attach Type</label>
<select id="attachType" class="form-control" name="attachType" required></select>
</div>
<!-- Attach Type End -->
<!-- Attach Num Begin -->
<label for="attachNum">Attach Num</label>
<input type="text" class="form-control" name="attachNum" id="attachNum" />
</div>
<!-- Attach Num End -->
<!-- Attach Loc Begin -->
<label for="attachLoc">Attach Loc</label>
<select id="attachLoc" class="form-control" name="attachLoc" required></select>
</div>
<!-- Attach Loc End -->
<!-- siteObs Begin -->
<label for="siteObs">Siteobs</label>
<select id="siteObs" class="form-control" name="siteObs" required></select>
</div>
<!-- siteObs End -->
<!-- Sign Shape Begin -->
<label for="signShape">Sign Shape</label>
<select id="signShape" class="form-control" name="signShape" required></select>
</div>
<!-- Sign Shape End -->
<!-- Color 2 Begin -->
<label for="color2">Color 2</label>
<select id="color2" class="form-control" name="color2" required></select>
</div>
<!-- Color 2 End -->
<button id="btnSignSubmit" class="btn btn-success" type="submit" style="visibility:hidden">Submit</button>
<button id="btnSignUpdate" class="btn" type="submit" style="visibility:hidden">Update</button>
<button class="btn btn-default" type="button">Cancel</button>
<button id="btnSignPrevious" type="button" style="visibility:hidden">Prev</button>
<button id="btnSignNext" type="button" style="visibility:hidden">Next</button>
</div>
</div>
</div>
<!-- Modal Dialog End -->
</div>
</form>
<!-- Attributes Sign Modal End -->
And the full version of the app is here:
csergent45/streetSigns at 1e5ccad65dbcdb7c427a2d248dd98a3d8a48e532 · GitHub
