Hello, I'm trying to write a code to copy the feature classes inside of feature datasets.
I'm having two issues. I have 2 feature datasets, but when I do the "print(fcList)" , seems like only the features one dataset are being listed. The second one is that the tool stucks at the arcpy.CopyFeatures Here below my code:
Thanks in advance for any tip.
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">from</SPAN> arcpy <SPAN class="keyword token">import</SPAN> env
env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:/Trials/NPD_FactMapsData_v3_0_2.gdb'</SPAN>
<SPAN class="comment token"># Set local variables</SPAN>
OutputFGDB <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:/Trials/New File Geodatabase.gdb'</SPAN>
<SPAN class="comment token">#env.workspace = arcpy.GetParameterAsText(0)</SPAN>
datasetList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListDatasets<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'*'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'Feature'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> dataset <SPAN class="keyword token">in</SPAN> datasetList<SPAN class="punctuation token">:</SPAN>
env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> dataset
fcList <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN>fcList<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> fcList<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'copying...'</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN>OutputFGDB<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"copy finished"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># Report if there was an error</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddError<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Could not copy feature classes"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Could not copy feature classes"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#print arcpy.GetMessages()</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
